cheap V8 engine
dcarrter21
That's about right if it comes with the ECU and ancilleries, otherwise it's better off buying a complete car.
The cost to convert is about the same as NA-TT if you were to do that route, but the power limitations of the 1UZ make it an extremely expensive modification route if you want more than a genuine 320bhp at the flywheel.
Also, after a local chap did his 1UZ conversion into a Mk2 Supra, they don't sound very "v8", even with big pipes.
