Ryan.G Posted March 10, 2010 Share Posted March 10, 2010 Would'nt the AEM FIC work great with a BL auto too m8? Be fine Link to comment Share on other sites More sharing options...
SupraHuman Posted March 10, 2010 Share Posted March 10, 2010 If you want big power on a auto then TH400 or Powerglide.. TH400 FTW:nana: Link to comment Share on other sites More sharing options...
dude Posted March 10, 2010 Share Posted March 10, 2010 TH400 FTW:nana: Plenty of 4 speed yank boxes that will take around 800hp and still have the over driven 4th gear. Link to comment Share on other sites More sharing options...
SupraHuman Posted March 10, 2010 Share Posted March 10, 2010 800 was yesteryear Dude. Don't need OD anymore. Link to comment Share on other sites More sharing options...
dude Posted March 10, 2010 Share Posted March 10, 2010 I know for a fact that the stock ecu pulls back the timing and closes the trac butterfly slightly to reduce the levels of torque going through the box. This is done for a reason and was done with the stock levels of torque in mind. When you add a single turbo into the equalation which adds around 150ftlb more torque its only a matter of time before the sprag gear breaks on the box. You just said it your self above.... was fine on the hybrids and went single and look what happened. If you want big power on a auto then TH400 or Powerglide.. Go on the AEM forum and type in Auto and well as auto and retard on supraforums! Ryan I would be frightened to type in retard on an american forum!!! So toyota pull timing to save the box at stock 0.8 bar hp and torque, then we add half that again and it still lives even though the small difference in timing pulled still leaves it way above stock!!! do the math the timing is pulled for smoother shifts to make the car drive nicer not to save a box that can live with an extra 150 hp and god knows what torque increase, the argument defeats itself as we are talking about tuned cars that put out way more than stock, it is done for refinement!!!! Link to comment Share on other sites More sharing options...
Jamesy Posted March 10, 2010 Author Share Posted March 10, 2010 800 was yesteryear . certainly will be with your new "little" set up mate!!! Link to comment Share on other sites More sharing options...
Miguel Posted March 10, 2010 Share Posted March 10, 2010 (edited) I would be frightened to type in retard on an american forum!!! So toyota pull timing to save the box at stock 0.8 bar hp and torque, then we add half that again and it still lives even though the small difference in timing pulled still leaves it way above stock!!! do the math the timing is pulled for smoother shifts to make the car drive nicer not to save a box that can live with an extra 150 hp and god knows what torque increase, the argument defeats itself as we are talking about tuned cars that put out way more than stock, it is done for refinement!!!! Although I can see your point I will have to disagree, you're looking at it wrong. The retard is there to alleviate slippage/snatch on the clutch packs and gearing when shifting. In much the same way you lift off in a manual. Yes, your'e going to bring up the fact that you can flat shift a Getrag and they are ok, except this too shortens the life expectancy of the box eventually if ignition cut isn't used ( ahem shift retard ;-)). The auto is weaker, fact, no need to dingle round it. The shift retard is not there to limit power going though the box but to give the box time to swap ratios with as little slippage/snatch as possible, which also helps to keep the heat down. It isn't the fastest way to shift, but it helps the box live, specially the 2nd gear sprag. Edited March 10, 2010 by Miguel (see edit history) Link to comment Share on other sites More sharing options...
Ryan.G Posted March 10, 2010 Share Posted March 10, 2010 I would be frightened to type in retard on an american forum!!! So toyota pull timing to save the box at stock 0.8 bar hp and torque, then we add half that again and it still lives even though the small difference in timing pulled still leaves it way above stock!!! do the math the timing is pulled for smoother shifts to make the car drive nicer not to save a box that can live with an extra 150 hp and god knows what torque increase, the argument defeats itself as we are talking about tuned cars that put out way more than stock, it is done for refinement!!!! Get a Standard auto on your dyno as see what the torque level is when it changes gear and then put on a single turbo auto which has the stock ecu (with trac enabled) in place with say an EMU or AEM and see what torque levels it puts out. You will find they are almost identical. I have looked into all this more than you think! Link to comment Share on other sites More sharing options...
dude Posted March 10, 2010 Share Posted March 10, 2010 Although I can see your point I will have to disagree, you're looking at it wrong. The retard is there to alleviate slippage/snatch on the clutch packs and gearing when shifting. In much the same way you lift off in a manual. Yes, your'e going to bring up the fact that you can flat shift a Getrag and they are ok, except this too shortens the life expectancy of the box eventually if ignition cut isn't used ( ahem shift retard ;-)). The auto is weaker, fact, no need to dingle round it. The shift retard is not there to limit power going though the box but to give the box time to swap ratios with as little slippage/snatch as possible, which also helps to keep the heat down. It isn't the fastest way to shift, but it helps the box live, specially the 2nd gear sprag. The other way of looking at it would be that if 'bangs' into gear there is less slipage and therfore heat and the clutch packs wikll last longer, how much less torque is the pulled timing resulting in for a split second??? We will prob have to agree to dissagree on this one but the guy I use for transmissions who builds boxes for 2000hp cars is the one who informed me of his views if you want a strong 4 speed auto you will need to go yank. As like you say Mig the 2nd gear sprag is very weak. Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted March 10, 2010 Share Posted March 10, 2010 http://www.atfbilletparts.com/transmission-parts-a340e-a341e-parts-c-197_117/a340e-intermediate-sprag-assembly-p-249 to help the sprag issue Link to comment Share on other sites More sharing options...
Miguel Posted March 10, 2010 Share Posted March 10, 2010 The other way of looking at it would be that if 'bangs' into gear there is less slipage and therfore heat and the clutch packs wikll last longer, how much less torque is the pulled timing resulting in for a split second?? We will prob have to agree to dissagree on this one but the guy I use for transmissions who builds boxes for 2000hp cars is the one who informed me of his views if you want a strong 4 speed auto you will need to go yank. As like you say Mig the 2nd gear sprag is very weak. I think we'll have to. In a perfect world were clutches never disengage, that would be the case. You of all people should know how much 6 degrees of timing pulled can drop power. I don't think anyone is disagreeing with your transmission guy that if you want big power you need to go with a yank box, pity about the massive transmission losses that come with them. Link to comment Share on other sites More sharing options...
dude Posted March 10, 2010 Share Posted March 10, 2010 I think we'll have to. In a perfect world were clutches never disengage, that would be the case. You of all people should know how much 6 degrees of timing pulled can drop power. I don't think anyone is disagreeing with your transmission guy that if you want big power you need to go with a yank box, pity about the massive transmission losses that come with them. that sprag looks interesting though Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted March 10, 2010 Share Posted March 10, 2010 that sprag looks interesting though take the time to look the other parts they sell the conversion kit and "flywheel" for 4l80e boxes , did see a few threads in Us that they installed and very good kit , and exellent service Link to comment Share on other sites More sharing options...
Jamesy Posted March 10, 2010 Author Share Posted March 10, 2010 Now ive decided to buy the BL box i feel much happier about it all. The fact Michel Lane has built it is a bonus!! Got the 3800 hi stall too but prob wontb use it for now. Link to comment Share on other sites More sharing options...
Miguel Posted March 10, 2010 Share Posted March 10, 2010 Now ive decided to buy the BL box i feel much happier about it all. The fact Michel Lane has built it is a bonus!! Got the 3800 hi stall too but prob wontb use it for now. Well at least that way if you don't like the way it drives you can swap in the higher stall. Link to comment Share on other sites More sharing options...
Nic Posted March 10, 2010 Share Posted March 10, 2010 Got the 3800 hi stall too but prob wontb use it for now. The GT35R should be making positive boost at just over 2000rpm so think you'll be better without it. Link to comment Share on other sites More sharing options...
Miguel Posted March 10, 2010 Share Posted March 10, 2010 The GT35R should be making positive boost at just over 2000rpm so think you'll be better without it. I reckon it would be a nice drive too. Link to comment Share on other sites More sharing options...
Jamesy Posted March 10, 2010 Author Share Posted March 10, 2010 The GT35R should be making positive boost at just over 2000rpm so think you'll be better without it. Yeah thats what Lee and I discussed earlier. Maybe a 3200 would be good but for now will try without one! I reckon it would be a nice drive too. Without one yeah? Well at least that way if you don't like the way it drives you can swap in the higher stall. exactly!! Link to comment Share on other sites More sharing options...
Miguel Posted March 10, 2010 Share Posted March 10, 2010 Without one yeah? Yes mate, I was agreeing with Nic. Link to comment Share on other sites More sharing options...
Jamesy Posted March 10, 2010 Author Share Posted March 10, 2010 Link to comment Share on other sites More sharing options...
Jamesy Posted March 10, 2010 Author Share Posted March 10, 2010 Just want to say a big thanx to CK (SupraHuman) .... Gave me a great deal on all the parts and explained the process to me in detail over the phone over the last few days. Has made this first step possible Link to comment Share on other sites More sharing options...
SupraHuman Posted March 10, 2010 Share Posted March 10, 2010 Just want to say a big thanx to CK (SupraHuman) .... Gave me a great deal on all the parts and explained the process to me in detail over the phone over the last few days. Has made this first step possible No problemo James, glad to help Link to comment Share on other sites More sharing options...
