David P Posted March 8, 2010 Share Posted March 8, 2010 (edited) The OEM wiper on drivers side only, was wiping up and missing the most important patch on way down. Fitted Mr T. spoilers. Wipe up, judder and skip down. :( Replaced the inserts with aftermarket rubbers. Wipe up, judder, skip and squeak down. :( Replaced all blades with Trico Neoform. Wipe up, and miss the most important patch on way down. :( :( Fitted new OEM arm. Wipe up, and miss the most important patch on way down. :( :( Passenger side and rear work perfectly? Aaaaaaargh! Edited March 8, 2010 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 9, 2010 Share Posted March 9, 2010 Move stearing wheel to other side Quote Link to comment Share on other sites More sharing options...
AlanM Posted March 9, 2010 Share Posted March 9, 2010 Mine did this after the respray. The wiper arms are sided, the hinge is in a slightly differt place on each. make sure you have a drivers arm on the drivers side. Wipers ain't the Supras best feature even when they are working correctly Quote Link to comment Share on other sites More sharing options...
David P Posted March 9, 2010 Author Share Posted March 9, 2010 (edited) LHD conversion had crossed my mind too It's a brand spanking new RHD Toyota drivers side arm. But now you mention your paint job................. I seem to remember that this anomaly began after fitting a U.K. T.T. bonnet scoop? It is fitted in exactly the same position as the TT, and in the same holes, does anyone know if the TT has a different part no. for the drivers side arm? Edited March 9, 2010 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
