Connecting PC to Plasma - Help Please
mr lover
I am trying to connect a PC to a Sony Wega Plasma TV, simple I hear you say :D
Here is the spec of the TV
Sony KDE P 42 XS 1
Screen Size 42 inch / 107cm
Aspect Ratio 16:9
Display Resolution Alis HD 1024 x 1042 (interlaced)
Resolution Enhancement WEGA Engine Technology
Sound System NICAM
Power Output (Music) 2 x 15W
TV System B, G, H, D/K, I, L
Colour System PAL / SECAM / NTSC 3.58 / 4.43
Inputs Input 1: SCART (AV in/out, RGB in)
Input 2: SCART (AV in/out, RGB in)
Input 3: SCART (AV In/out, S-Video in)
Front: 1x Composite, 1x S-Video, PCMCIA Card Slot
Rear: 1x Component, PC
Outputs 1x Audio (Stereo)
1x 3.5mm
Power Consumption (standby) Media receiver 373W (1.9W)
Power Requirements 220-240v,50/60Hz
Dimensions (Display) with stand Width 1229mm
Height 753mm
Depth 286mm
Dimensions (Media Receiver) Width 430mm
Height 79mm
Depth 343mm
Weight 39kg Display
6kg Media Receiver
Now I assume that I need to utilise the PCMCIA Card Slot, but what do I need? I have had a google but to be honest I am not sure what I am looking for.
Any help much appreciated :)
No, the PCMCIA slot is a CAM slot for freeview and that sort of thing. You will want to use either the HDMI or VGA connector from the PC.
Exactly..... if your pc does not have HDMI out just VGA you will need a VGA -->HDMI lead as pictured.
Scotty
It says PC on the rear? Just trying to find the manual for it.
That would be component inputs ie vga to component red/green/blue?
No HDMI:blink:
Well you can go (looking at your inputs)
VGA to Scart
VGA to S Video - Audio
VGA to Component
Plenty of cables/options for you
Go for VGA to Component as below
scotty
It should have a VGA socket on the back, something like this.
Alternatively, you will need a VGA to component lead.
http://www.hdtvitaly.com/catalog/images/d_2560.jpg
Dont expect any super resolutions though, your TV only does 1024x1024.
No HDMI:blink:
VGA to Scart
VGA to Component
http://i5.photobucket.com/albums/y164/dvdhouse/pothvgargbx6_cb_l.jpg
scotty
Cheers Scotty, no no HDMI, TV is about 5 years old
VGA to component looks exactly what I need, cheers
http://farm3.static.flickr.com/2550/3811864542_1e11553fa8_o.jpg
Again thanks, TV does not have VGA socket
Hold on a sec, this isn't one of those panels that has a separate system is it? I think it may be... Do you have the other box?
No other box Gav, just TV and remote
Thanks for the help guys
Unless Gav's onto something, your best bet might be to connect the SVideo output from the PC to the SVideo input of the TV. From what I've read, trying to convert VGA to other types of signal is either problematic and/or comparatively expensive. A 5m SVideo cable costs a couple of quid.
