removing spigot bearing
barneybrendan
Easy way: With a slide hammer and a split collet bush removing tool.
Trickier but another possible way: Close fitting round steel bar, pack spigot bearing with grease (NO air voids)insert bar into the end of the bearing, belt bar with big hammer, the grease hydraulics out the bearing, or repeat until successful or you give up and buy the right tool.
OK, right, I only glanced at it, that should be fine then. There's not much choice between the proper tool and the hydraulic trick. I have got dozens of bushings out with grease where I haven't had the right collets. It does work, with patience. Sometimes they just pop straight out, sometimes they can be a PITA.
I used a slide hammmer with modified bolt. I ground the bolt hex head to something more round (180deg worth of it) and then hooked the head round the back of the bearing. Pulled it out with reasonable ease.
Another method is to use an appropriately sized rawlbolt. I failed with this method, but that may have been my own fault.
Used the rawbolt a few times bud, always done the trick for me.
