NA-t Head Gasket choice?
Supra_Scott
Hi, i have a NA-T Supra running the following spec:-
T70 Turbo with T3 flange
Stainless manifold
HKS style 50mm wastegate with 7psi spring and screamer pipe
God Speed FMIC
HKS style BOV
HKS induction kit
JIC Bullet exhaust
MKIII 440c injectors with resistor pack
Fuel pressure regulator with guage
TT spark plugs
Stock internals, headgasket and fuel pump
5 speed gearbox.
The car is mapped for 6psi boost but i want to safely run a Bar. I appreciate i need an uprated fuel pump etc but could do with some advice on HG choice please and also stockists. I am aware the lads on the ClubNA-T forum usually use a 1.3mm XS Power HG but would like to see what people are running over here.
Thanks, Scott
Guest Budz86
I think the HKS one's are ment to be good. Although I can't remember all the details as it ages ago I heard this.
Not too sure about the XS Power brand, heard bad things about them. A search on here should bring up some threads
