cabin fumes
Chiefgroover
I get my fair share of cabin fumes, which i really dont want.
This is something I never had on stock tubbies so put it down to being a big single, I have routed the fuel breather pipe from the tank into the wing, where the bottom of the charcoal cannister would go, but still get it, anyone know the answer?
Do you get it just when you come to a stop? I've always had that since a decat, all that unburnt fuel from exhaust catching up with you when you stop at a junction!
Shouldn't get it on idle though, unless the wind is blowing from the back to the front of the car.
Does the Supra have an activated carbon pollen filter? I've never checked or searched :search:
EDIT: Just found out they don't
Supra's do NOT have pollen filters
Edited by leelbuk (see edit history)
What fuel pump mount are you using? I've found that the WOTM one is too large a diameter for the pump - tank o'ring seal to fit corrcetly so I always have a strong fuel smell.
I've got to pull the whole lot out of the back and get it turned down to the same size as stock. I think it's only a mm or so, but there's no way the o'ring fits correctly as it is.
