ReNe0 Posted March 2, 2010 Share Posted March 2, 2010 Hey People. I need to change my clutch on my Supra. Is there a easy way to get to gearbox off the engine ? It is af 6 speed. Greetings. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 2, 2010 Share Posted March 2, 2010 Taking the bellhousing bolts out by undoing them is the accepted way Given suitably large power tools and cut off discs opens up a multitude of other options though. Link to comment Share on other sites More sharing options...
ReNe0 Posted March 2, 2010 Author Share Posted March 2, 2010 All the bolts are out But im stock now. I cant get the gearbox more than 50 mm from the engine. I think this maybe the problem ? Does this has to come off, before i can continue? http://peecee.dk/uploads/032010/1.jpeg http://peecee.dk/uploads/032010/2.jpeg http://peecee.dk/uploads/032010/3.jpeg Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 2, 2010 Share Posted March 2, 2010 Take the release arm out (pull it hard). Then remove all six bolts holding the clutch cover to the flywheel, turning the engine to get at them all. Carefully lever the cover away from the flywheel until it will turn freely on its own. THEN take the gearbox off the engine. Link to comment Share on other sites More sharing options...
ReNe0 Posted March 2, 2010 Author Share Posted March 2, 2010 Thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 2, 2010 Share Posted March 2, 2010 No problem, the whole clutch assembly stays on the gearbox input shaft, not on the flywheel. It goes back in the same way. BE SURE to get all the washers and circlips for the release bearing assembly back together properly on the new clutch. I can e-mail a page from the factory manual showing this if you are in doubt, but not until tomorrow. Link to comment Share on other sites More sharing options...
ReNe0 Posted March 2, 2010 Author Share Posted March 2, 2010 I will appreciate that Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 3, 2010 Share Posted March 3, 2010 I have uploaded the section here: http://www.chriswilson.tv/clutch.pdf Link to comment Share on other sites More sharing options...
ReNe0 Posted March 3, 2010 Author Share Posted March 3, 2010 Thanks Link to comment Share on other sites More sharing options...
