xbox live help please
Rob_Mitchell
hello people i need some help before all my hair falls out, or i throw my xbox at the wall.
i have decided to finally try and get up live on the xbox, i bought a xbox wireless adaptor and plugged it all in but all i get is a flashing green light and its not picking up the wireless :search:
im so useless at computers so dont know much about what i need to do im going crazy
is there any whizz kidds on here or anyone who fits these things who can help??
sorry if i sound like a dump arse, thanks
have you set it up to look for your wireless hub or what ever you have
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Then save it.
how do i do that? its like training a peperami to play the violin, im useless i think it might be best to pay to get someone to fit it lol
don't you go into connection settings ?
i use a cable more stable and faster :)
yeah i am considering drilling a hole in my roof at the moment, just to get on line lol i have been mucking around since 7 lol
Then save it.
mate cheers, wireless settings is not even listed there lol i think i need to try again tomorrow and have a fresh head on and read what you put again. my eyes are all squared up
When I set my Xbox up I completely forgot that my router has a MAC Address list - and unless the MAC Address of the network device was entered it simply wouldnt allow it to connect.
This could be the case if the above guide by Nevins doesnt get it sorted. Sounds like your wireless network was set up by someone for you?
right fresh start, when i follow the pics above i get to configure network and all the information is 0.0.0.0 in every box, do i some how have to fill this in? if its set on automatic should it find my wireless find the xbox automatically? my wireless modem is downstairs im wondering if the signal is no good? but my laptop works upstairs
i was going to try and put the modem upstairs and try that tonight see if it picks something up. i just cant understand why im not getting the wireless mode part in the basic settings because from there its easy, i have put the disc in which i got with the xbox adaptor but nothing happens, they say if nothing happens i already have the update done at some point
