Dry sump for 2JZ
Chris Wilson
As a gear pump is loaded pretty much relative to the pressure ratio across it and all but one section are just sucking and feeding an effectively open vessel, not as much as they might look as though they would :) Quite why anyone thinks it needs four scavenge sections just on the sump I don't know, 2 should do, 3 would be plenty, IMO.
Seems a bit pointless to me.
The sump on it is about the same size as stock, so there won't be any benefits in terms of reducing the height of the block.
The sloshing caused by acceleration, longitudinal or otherwise shouldn't be a problem to an engine with the correct amount of oil in.
  • 5 months later...
Guest Twins Turbo INC
Hea guy's, I just was sent this by someone..
We have these dry sump systems running all over the globe. On road race as well as Drag cars for about 2 years now. Even on one or two street cars.
If any of you have questions about our system or the 2JZGTE, I will do my best to monitor this and get the answers over to you.
Thanks for looking at the kit and our site.
Eric
Twins Turbo
