Baz018 Posted February 27, 2010 Share Posted February 27, 2010 Needing to get my tts reconditioned and if poss so they can run more boost. Any1 Know the best place to get this done??? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted February 27, 2010 Share Posted February 27, 2010 CR turbos will do it for around £600 Quote Link to comment Share on other sites More sharing options...
Thorin Posted March 1, 2010 Share Posted March 1, 2010 Are they actually broken or are you just wanting hybrids to run more boost? You'll still not be able to run much more boost on hybrids, so if there's nothing wrong with your turbo's currently it's probably not worth it. Quote Link to comment Share on other sites More sharing options...
caseys Posted March 1, 2010 Share Posted March 1, 2010 When you say you want to run more boost as Thorin said above what are you running? If you're running 1.2 bar odd now and think you can run more with a rebuild I'm afraid that won't be the case... Quote Link to comment Share on other sites More sharing options...
Baz018 Posted March 1, 2010 Author Share Posted March 1, 2010 Well one of the turbos has bad damage to the blade part things. Could do with reconditioning but just thought if i could make them run more boost i may as well do it now. But if not i aint bothered. Quote Link to comment Share on other sites More sharing options...
Baz018 Posted March 1, 2010 Author Share Posted March 1, 2010 C R Turbos want £800 for both turbos. Quote Link to comment Share on other sites More sharing options...
fullrespect Posted March 12, 2022 Share Posted March 12, 2022 Hi i have recently purchased my Supra with some BPU's. Its Jap Import. It currently goes up to 1.0 Bar and cuts off as there is no FCD fitted (yet). In my case i would like to run more boost (up 1.4 bar). The turbos does not show any signs of wearing out or leaks. Do you think it is a good idea to rebuild stock jap spec turbos to a UK spec (replace ceramic blades with metal ones)? If so - who will be the best in the market to perform the task properly and professionally? Or is it better to simply look for a single turbo instead? Thanks! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 12, 2022 Share Posted March 12, 2022 Its definitely a good idea, and its a well trodden path. Why 1.4bar? Theres several threads on here about it, just search 1 Quote Link to comment Share on other sites More sharing options...
Bender Posted March 12, 2022 Share Posted March 12, 2022 I rebuild mine at Midland Turbo (Inc metal inserts) and can recomended them 2 Quote Link to comment Share on other sites More sharing options...
fullrespect Posted March 13, 2022 Share Posted March 13, 2022 On 3/12/2022 at 10:49 AM, Bender said: I rebuild mine at Midland Turbo (Inc metal inserts) and can recommended them Hi, can you share the costs involved? And what exactly was done and what was replaced? How long (mileage) do you use them in your car since the rebuild? Thanks! Quote Link to comment Share on other sites More sharing options...
Bender Posted March 13, 2022 Share Posted March 13, 2022 10 minutes ago, fullrespect said: Hi, can you share the costs involved? And what exactly was done and what was replaced? How long (mileage) do you use them in your car since the rebuild? Thanks! Sure it cost me £650 for both of them plus they do service on them change seals bearings remove carbon etc plus steel inserts another £200 for set of used twins as one of mine blown so badly that they couldnt refurb. I change them last year november or December and they still working fine and i use my supra daily i guess i done around 1000km 1 Quote Link to comment Share on other sites More sharing options...
fullrespect Posted March 13, 2022 Share Posted March 13, 2022 Thanks @Bender I would go and do the same with mine, but i just cant trust enough the companies who rebuild them, its very hard for me as i read many bad things after some rebuilds done in the UK in general. I think i need to grab a phone and ring all the firms known for refurbing the Supra turbos and then will make my mind up. By the way - is it a hard job to remove the twins by self? Quote Link to comment Share on other sites More sharing options...
Bender Posted March 13, 2022 Share Posted March 13, 2022 3 hours ago, fullrespect said: Thanks @Bender I would go and do the same with mine, but i just cant trust enough the companies who rebuild them, its very hard for me as i read many bad things after some rebuilds done in the UK in general. I think i need to grab a phone and ring all the firms known for refurbing the Supra turbos and then will make my mind up. By the way - is it a hard job to remove the twins by self? Midlands Turbo was recomended by some guys on the forum so thats why i choose them (BTW you need to ask for Liam) and tbf very happy with service they provide. About removing twins its duable job on your driveway just need few tools lots of patience and a bit of time i think there was some "how to" on internet i got a bit easier as i used my brother in law who help me a lot 1 Quote Link to comment Share on other sites More sharing options...
m12aak Posted March 16, 2022 Share Posted March 16, 2022 On 3/13/2022 at 5:50 PM, fullrespect said: Thanks @Bender I would go and do the same with mine, but i just cant trust enough the companies who rebuild them, its very hard for me as i read many bad things after some rebuilds done in the UK in general. I think i need to grab a phone and ring all the firms known for refurbing the Supra turbos and then will make my mind up. By the way - is it a hard job to remove the twins by self? I haven't removed stock twins myself but I have this how-to saved for when I do: https://www.diyauto.com/manufacturers/toyota/generations/supra-a80/diys/stock-twin-turbo-removal-by-94canuck. Bear in mind it may not be 100% applicable to a jspec car as they're working on a US car but from the looks of it much is the same, so use of this guide with the turbocharger Toyota service manual should make it pretty straightforward! 1 Quote Link to comment Share on other sites More sharing options...
fullrespect Posted March 18, 2022 Share Posted March 18, 2022 Thanks Izaak, this will defo help a lot! 1 Quote Link to comment Share on other sites More sharing options...
Celicasaur Posted March 18, 2022 Share Posted March 18, 2022 what's the highest trap speed you can expect out of rebuilt twins with say, GT28 wheels inside them as well? 120mph? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 18, 2022 Share Posted March 18, 2022 What do you mean? Quote Link to comment Share on other sites More sharing options...
