Warning light?
RobAce
ok i have i have now finished my 6 speed manual conversion and i have changed the dash clocks over but the triangle warning light on the dash is constantly lit, even though the car seems to drive fine.
does anyone know wot this light might represent or wot faults it lights for
rob
Is that the the same warning sign when doors are open or hand brake is up in the centre of the speedo?
i have the same warning light constantly on.. have had it diagnosed from two different guys but no fault is showing up!!
Yes it's the same light. First place to check when the lights comes on for no apparant reason. Quite sensitive the ol' fluid reservoir.:D
Edited by SupraHuman
Spelling (see edit history)
Start with the simplest things that you have disturbed recently, try the switch on the hand brake.
i did think that but the other warning light on the dash still goes out when u take the hand brake off , just leaves the triangle on
I will check for fault codes.
As you have already mentioned, it may not throw up anything if there are no other lights partnering it (assuming all your warning bulbs work), but you never know.
I would retrace my steps and check all the connections. Did you swap the clocks over to manual ones? Maybe swap them back as a test.
