gjp Posted February 26, 2010 Share Posted February 26, 2010 Has anyone fitted a clock with a outside temp display to their car. I forgot I bought this until I found it in my tool box. I looked at it today and noticed that the sockets are different from the std clock from my car. I will also need to run wires to a temp sensor. Any ideas Link to comment Share on other sites More sharing options...
merckx Posted February 26, 2010 Share Posted February 26, 2010 I forgot I bought this until I found it in my tool box. Bought what? I looked at it today and noticed that the sockets are different from the std clock from my car Why would they be the same, whatever it is? Link to comment Share on other sites More sharing options...
Ric Posted February 26, 2010 Share Posted February 26, 2010 there are differences, the Temp sensor is from the UK model, i'm unsure if the cabling/sensor is present on the Jspec cars Link to comment Share on other sites More sharing options...
gjp Posted February 26, 2010 Author Share Posted February 26, 2010 Bought what? Why would they be the same, whatever it is? You get out of the wrong side of bed today Link to comment Share on other sites More sharing options...
merckx Posted February 27, 2010 Share Posted February 27, 2010 You get out of the wrong side of bed today Nope, I can't the bed is against the wall. I get annoyed at reading posts on here that cannot be easily understood. That's why they get few if any at all replies. Link to comment Share on other sites More sharing options...
Ric Posted February 27, 2010 Share Posted February 27, 2010 Whats so hard to understand about his first post? hes asking if anybody has fitted the UK clock (with temp sensor) to a jspec? He forgot he had it, and its been sat in his tool box and only just come round to looking at it (we don't need to know that, but its hardly OMFhgfghfsa]gdklfbhopdfgni) ? And if he needs to run wires to a temp sensor? Oh and the plugs different to the socket on the clock Link to comment Share on other sites More sharing options...
merckx Posted February 27, 2010 Share Posted February 27, 2010 (edited) So you're saying that the question was clear and easily understood? hes asking if anybody has fitted the UK clock (with temp sensor) to a jspec? Where does it say that he bought a UK spec clock, there're plenty of aftermarket gauges available? There's an obvious difference between the two words "presuming" and "knowing". Edited February 27, 2010 by merckx (see edit history) Link to comment Share on other sites More sharing options...
SteveC Posted February 27, 2010 Share Posted February 27, 2010 If it's of any help, the ambient air temperature sensor on a UK Supra is part number 88625‑14110 and costs about £25. If your car has a/c, then an ambient air temperature sensor and associated wiring may already be fitted. The location of the sensor is shown in attached diagram (it clips into the upper face of the front bumper opening to the radiator). It's not a complete answer to your question, but it's a start... Link to comment Share on other sites More sharing options...
Sharpie Posted March 10, 2010 Share Posted March 10, 2010 Yep, the air temp sensor is located up front. Link to comment Share on other sites More sharing options...
dive_popo Posted March 11, 2010 Share Posted March 11, 2010 On my jap spec I had this sensor, i just installed Uk clock and miracle it's working !!! :D:D:D it took about 40 seconds.... Link to comment Share on other sites More sharing options...
bodilx6 Posted March 12, 2010 Share Posted March 12, 2010 COOOOOL!!! I want that!!! Does anyone know anything about using the sensor with any other readout than the OEM clock (which I removed to fit a boost meter). Link to comment Share on other sites More sharing options...
SteveC Posted March 12, 2010 Share Posted March 12, 2010 ...Does anyone know anything about using the sensor with any other readout than the OEM clock... Unfortunately, it's extremely unlikely that you'll find another form of readout that will give an accurate temperature reading with the Toyota ambient temperature sensor. Both the readout and sensor should be designed and calibrated to work together. Link to comment Share on other sites More sharing options...
ufop Posted March 29, 2010 Share Posted March 29, 2010 something I need to do to mine too wired it up but not connected it up to the sensor so I dont know if its going to work or not sadly Link to comment Share on other sites More sharing options...
bodilx6 Posted March 30, 2010 Share Posted March 30, 2010 Let us know!! Link to comment Share on other sites More sharing options...
imi Posted May 7, 2011 Share Posted May 7, 2011 On my jap spec I had this sensor, i just installed Uk clock and miracle it's working !!! :D:D:D it took about 40 seconds.... how did you plug a UK clock into a Jspec Supra, the clock connector is different (6 wires as supposed to 4) Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 7, 2011 Share Posted May 7, 2011 TICK added to my long list of jobs Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 9, 2011 Share Posted May 9, 2011 Just to add to this ive got a jap import and the sensor is already fitted to mine.good times!!! Link to comment Share on other sites More sharing options...
imi Posted May 9, 2011 Share Posted May 9, 2011 Just to add to this ive got a jap import and the sensor is already fitted to mine.good times!!! the sensor is fitted to all supras with air con. the question is whether the clock connector is the same (6 wires) as supposed to 4 (additional two for the temp sensor). If there are only 4 wires, where do two additional wires need to be connected to? Link to comment Share on other sites More sharing options...
imi Posted May 9, 2011 Share Posted May 9, 2011 A wiring diagram for the clock (specifically UK spec clock) would help - want to figure out how the clock temp sensor gets its signal from (could it be the ECU)? Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 9, 2011 Share Posted May 9, 2011 On my jap spec I had this sensor, i just installed Uk clock and miracle it's working !!! :D:D:D it took about 40 seconds.... well i saw this so may just give it a go,has anyone got a pic of the clock with the temp showing as ive never seen one? about to put my dash back together so my be the right time to get a uk clock put in Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 9, 2011 Share Posted May 9, 2011 A wiring diagram for the clock (specifically UK spec clock) would help - want to figure out how the clock temp sensor gets its signal from (could it be the ECU)? Will look this up another day as ive had my head in wiring diagrams for the speedo clocks all day! (fitted shift light) Link to comment Share on other sites More sharing options...
Westy Posted May 9, 2011 Share Posted May 9, 2011 Why bother!? Am I missing something here!? Link to comment Share on other sites More sharing options...
imi Posted May 9, 2011 Share Posted May 9, 2011 Why bother!? Am I missing something here!? a clock that reads outside temp, the thread title gives it away. Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 9, 2011 Share Posted May 9, 2011 a clock that reads outside temp, the thread title gives it away. Link to comment Share on other sites More sharing options...
Westy Posted May 9, 2011 Share Posted May 9, 2011 a clock that reads outside temp, the thread title gives it away. :clown:I knew that...statement was more towards why does outside temp matter!? Why is that something you would NEED to know!? Link to comment Share on other sites More sharing options...
