lounge decor
barneybrendan
was thinking white walls with random red squares myself.
Don't got white, shows up the marks too easily... I've got mag with red circles. Will take a pic quick..
EDIT : Done, ignore the mess, busy redecorating the whole house and attempting to loose almost 1km of cabling.
thats the sort of thing i had in mind .better now to see something like i had in my head
All we did was use a pencil and a bit of string, draw random outlines all over, overlapping that sort of thing. The main wall was red with magnolia circles and the rest are mag with red circles. Use plates anything that is circular really :)
I will add if you live in a typical brit house with plasterboard walls be prepared to turn them into swiss cheese hiding cabling. I used a circle saw on a drill and to put holes near all the stud work to ease the cabling through. The reason I use that is they cleanly remove a core which you can then put back in and fill. ALWAYS over estimate with the wiring and never underestimate how big the bundle will end up.
