safcdixon Posted February 23, 2010 Share Posted February 23, 2010 As per title is there any way of removing paint from a carbon bonnet without damaging the carbon, it's been on since my dad bought his supra a few year ago a it looks cac tbh and the is car kawasaki ninja green you can vision how bad it looks thanks marc Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 23, 2010 Share Posted February 23, 2010 (edited) Thats a tricky one and i'll be amazed if it can be done without affecting the c/f underneath. I take it the c/f bonnet was laquered and then someone painted over it ? if so then they should have flatted the laquer to take the shine off to get the paint to stick to it so who knows what you might find under the paint if you can get it off. I guess thinking out loud you could possibly da the bonnet with flatting discs if your real carefull but it might take quite a while, taking extra care not to go though the laquer inbetween the paint and the c/f. Edited February 23, 2010 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
safcdixon Posted February 23, 2010 Author Share Posted February 23, 2010 is it possible to re shine the carbon afterwards? if i cock it up because its been done so that the carbon is a wide stripe through the middle and the paint is down the sides of the bonnet Quote Link to comment Share on other sites More sharing options...
S44M KT Posted February 23, 2010 Share Posted February 23, 2010 pics would probably help Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 23, 2010 Share Posted February 23, 2010 Carbon is only shiny because its been laquered over just like you do with paint on cars. If you sanded through the laquer onto the carbon im not sure what would happen, what you could do with is a sample piece of painted carbon and try sanding it down and see what happens. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 23, 2010 Share Posted February 23, 2010 pics would probably help How Quote Link to comment Share on other sites More sharing options...
David P Posted February 23, 2010 Share Posted February 23, 2010 Before you attack it with abrasives, try a test patch with paint stripper and rub with a soft cloth. I don't think the stripper will affect the carbon, but test it first. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 23, 2010 Share Posted February 23, 2010 I would be very Wary of what you put on carbon fibre, the low grade stuff is often done using fibreglass resin, and if it is them any paint stripper will not do it any favours. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted February 23, 2010 Author Share Posted February 23, 2010 not the best pic but its the only one i could find of it from the front its in the background lol Quote Link to comment Share on other sites More sharing options...
safcdixon Posted February 23, 2010 Author Share Posted February 23, 2010 i had thought of turps but didnt know if it would ruin the carbon too Quote Link to comment Share on other sites More sharing options...
chazuk Posted February 23, 2010 Share Posted February 23, 2010 Start with a 250 grit lightly sand it while keeping it wet with water, once the colour is almost off use a 400grit wet still and take the remaning colour off now go to 800 grit and give it a once over it will probably be a milky white substance this is the orginal clearcoat on the carbon wipe dry and look for scratches that may have been from the sanding and remove these as this will show , now you to apply a clearcoat lacquer/clear gel coat or you might be lucky enough it might mop up ... good luck Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 23, 2010 Share Posted February 23, 2010 I would be very Wary of what you put on carbon fibre, the low grade stuff is often done using fibreglass resin, and if it is them any paint stripper will not do it any favours. Agreed. I personally wouldnt go anywhere near it with paint stripper, sanding it back very carefully with a da is the only way in my opinion. A lot will depend on how much paint is on the bonnet, can you see the carbon weave through the paint ? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted February 24, 2010 Author Share Posted February 24, 2010 Na you can't see the weave it's smooth and it's very green so the best option is to mop it off I think it's worth a shot and would improve the look of the car Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 24, 2010 Share Posted February 24, 2010 Na you can't see the weave it's smooth and it's very green so the best option is to mop it off I think it's worth a shot and would improve the look of the car You wont mop it off mate, that would take forever. You need to da it off using flatting pads. Start with a coarse grade to knock the top off but be carefull you dont go through into the c/f, then get a finer grade to work down to the c/f and fingers crossed. Quote Link to comment Share on other sites More sharing options...
lui Posted February 24, 2010 Share Posted February 24, 2010 I had my top secret carbon bonnet II with all the lacquer striped back done once before by GVN looked awful when stripped back very dull but once prep was done & re-lacquered came up like brand new bonnet Quote Link to comment Share on other sites More sharing options...
jackso11 Posted February 24, 2010 Share Posted February 24, 2010 if the carbon is laquered then its just a case of sanding down through the paint and not all the way through the laquer. Then smooth it, and re laquer. Should be an easy enough job for a paint shop. Quote Link to comment Share on other sites More sharing options...
