Ganty Posted February 23, 2010 Share Posted February 23, 2010 hi all could anyone tell me where i can buy the the o ring seal from where the drive shaft goes in to the diff box, as mines leaking and throwing oil everywhere. Thanks in advance:) Quote Link to comment Share on other sites More sharing options...
Nic Posted February 23, 2010 Share Posted February 23, 2010 Toyota. Quote Link to comment Share on other sites More sharing options...
Ganty Posted February 23, 2010 Author Share Posted February 23, 2010 Toyota. was hoping so lol! was'nt sure if it was a main dealer part or not have you any idea on a part number nic? Thanks:) Quote Link to comment Share on other sites More sharing options...
Nic Posted February 23, 2010 Share Posted February 23, 2010 Toyota part department should be able to get you the seal. Sorry I don't have the Toyota EPC on this machine, I'm sure someone will be along in a minute who can help with the part number. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted February 23, 2010 Share Posted February 23, 2010 As far as I can figure it out your options are these: If your car is an auto the part# is 90311-44005 If your car is a 6 speed the part# is 90311-50018 Quote Link to comment Share on other sites More sharing options...
Nic Posted February 23, 2010 Share Posted February 23, 2010 As far as I can figure it out your options are these: If your car is an auto the part# is 90311-44005 If your car is a 6 speed the part# is 90311-50018 The early model 6spd 2JZGTE had the larger diff fitted, all other models including the 6spd VVTi 2JZGTE had the smaller diff fitted. This will be why there are 2 part number options. I'm guessing if yours is a 95 manual TT it should have the larger diff fitted, so the bottom number should be the correct one. On the pic below left is the larger diff, right is the smaller diff. I'd double check which you have to be sure. http://img210.imageshack.us/img210/2994/supravsoarerex8.jpg Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted February 23, 2010 Share Posted February 23, 2010 Damn, now I'm confused! Was the large diff only found in UK 6 speeds or ALL (UK & JDM) early 6 speeds? Quote Link to comment Share on other sites More sharing options...
Nic Posted February 23, 2010 Share Posted February 23, 2010 Damn, now I'm confused! Was the large diff only found in UK 6 speeds or ALL (UK & JDM) early 6 speeds? Larger diff - UK and J-spec early model 6spd 2JZ-GTE Smaller diff - All 2JZ-GE, all auto 2JZ-GTE, all VVTi 2JZ-GTE Can you post the EPC part number section and illustration? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted February 23, 2010 Share Posted February 23, 2010 The parts page I was working on because I assumed the car was JDM and therefore had the small diff but this may not be the case now. http://www.toyodiy.com/parts/p_J_1995_TOYOTA_SUPRA_JZA80-ALFQZ_4101.html Quote Link to comment Share on other sites More sharing options...
Ganty Posted February 23, 2010 Author Share Posted February 23, 2010 Ok will have to get that checked before I order.Thanks for the info guys! Quote Link to comment Share on other sites More sharing options...
