handbrake light always coming on
seanfraser
Nics answer is the most common cause.
If you say it goes out when nudged it could well just be the sensor on the handbrake lever. It's easy to access - remove the centre glovebox and you can see the switch and connector. It's only held in with a small screw and they can come loose (though only ever seen it twice)
