uPVC door trim part name
edge
I need a replacement section for my double sliding doors.
I have done all sorts of different searches but have no idea what its called or where to get the bit.
The bit i need is the part that you would step on or over when going through the doors ans its about 3 inches thick and just under a meter long and so is the part i need :eyebrows:
It just clips on the bottom section and the same for the top but thats in white but i need a black bit.
any ideas?
That is what is fitted to most older ali patio door's, new one's tend to be white and a slightly different finish.
I would just take it of, should unclip quite easy with a putty knive. Take it to a local window company as they will more than likely either have one or keep one for you when they next remove a patio.
