JamieP Posted February 21, 2010 Share Posted February 21, 2010 Without taking them apart? anyone done it? Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted February 21, 2010 Share Posted February 21, 2010 when you take them apart jamie you will crack the paint that seals the openings if you get what i mean. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 21, 2010 Author Share Posted February 21, 2010 when you take them apart jamie you will crack the paint that seals the openings if you get what i mean. Im not planning on ever taking them apart Adnan. Quote Link to comment Share on other sites More sharing options...
Kirk Posted February 21, 2010 Share Posted February 21, 2010 I dont see why not if there all going one colour Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 21, 2010 Author Share Posted February 21, 2010 Yup all one colour, the powder coater seems to think they will be fine, just wanted a second opinion before i spend the money. Quote Link to comment Share on other sites More sharing options...
Homer Posted February 21, 2010 Share Posted February 21, 2010 From what I've read before it will depend on the wheel design, though in general it doesn't seem to be recommended. Are they bolted split rims? Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 21, 2010 Author Share Posted February 21, 2010 Yup bolted, is there any other way of fixing split rims together? ill try and find a pic. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 21, 2010 Author Share Posted February 21, 2010 Look like these i think. Quote Link to comment Share on other sites More sharing options...
JustGav Posted February 21, 2010 Share Posted February 21, 2010 I don't see why not, my guys have done them before... It does mean that it would hassle to split them again though. Quote Link to comment Share on other sites More sharing options...
jimbo482 Posted February 22, 2010 Share Posted February 22, 2010 is it kawasaki green you are going for? Quote Link to comment Share on other sites More sharing options...
pezzler Posted February 22, 2010 Share Posted February 22, 2010 On a slight tangeant... As well as being bolted, are splits rims interference fit? Must a lot of heat be applied to the rim to remove the centre piece? Quote Link to comment Share on other sites More sharing options...
nevins Posted February 22, 2010 Share Posted February 22, 2010 On a slight tangeant... As well as being bolted, are splits rims interference fit? Must a lot of heat be applied to the rim to remove the centre piece? ??, I thought split rims were just two halves unless they were 3 piece rims. Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted February 22, 2010 Share Posted February 22, 2010 jamie, if your never going to take the rim apart and your sure of this then no problem you can do it without taking them apart. if in the future something happens and you have to take it apart then it will ruin the paint job because your going to have to crack the paint in order to get the centre out. a lot of people take them apart because they like changing the colours of the inner bit. Quote Link to comment Share on other sites More sharing options...
markylee Posted February 22, 2010 Share Posted February 22, 2010 i like them, they remind me of the stock wheel . Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 22, 2010 Share Posted February 22, 2010 A lot will depend how they are sealed, some split rims use a large o ring to do this which sits between the 2 halves if 2 piece, the heat from the powder coating oven will more than likely ruin that seal if thats how yours are sealed, you might have to strip the 2 pieces apart to change that seal. Powder coat oven is 200 degrees C and they will be in there for approx 20 mins. If their 3 piece then they will more than likely be sealed in the tyre well where the 3 pieces meet, this is done with a Sikaflex sealer like silicon, that will also cook and need to be removed and re apply new but that can be done without stripping the wheels. The downside in powder coating them complete will be all the bolts will get done and in my opinion that looks crap. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 22, 2010 Share Posted February 22, 2010 From what I've read before it will depend on the wheel design, though in general it doesn't seem to be recommended. Are they bolted split rims? I see no reason why you cant do it apart from the question regarding the sealing of the 2 or 3 pieces. Ibrar has done quite a few for customers with no problems . How else can they be held together if not by bolts ? Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 22, 2010 Share Posted February 22, 2010 On a slight tangeant... As well as being bolted, are splits rims interference fit? Must a lot of heat be applied to the rim to remove the centre piece? No their not interferance but usually a close clearance fit. No heat required to split them and if their stuck together a rubber mallet ususally does the trick. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 22, 2010 Author Share Posted February 22, 2010 Just dropped them to be powder coated, pics soon:) Quote Link to comment Share on other sites More sharing options...
probrox Posted February 22, 2010 Share Posted February 22, 2010 I'd be interested in the cost of powder coating as one piece. I've been wanting to get mine done but haven't due to lacking funds and the extra cost of splitting. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 22, 2010 Share Posted February 22, 2010 I'd be interested in the cost of powder coating as one piece. I've been wanting to get mine done but haven't due to lacking funds and the extra cost of splitting. If their not being taken apart then surely there the same cost as a 1 piece but with a small charge for removing the sealer and re applying new. If there sealed with sealer that is and not the o ring type. Ask Ibrar for prices ! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 22, 2010 Share Posted February 22, 2010 nice rims jamie look forward to seeing them coated, they you track rims (oz racing?) Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 22, 2010 Author Share Posted February 22, 2010 I'd be interested in the cost of powder coating as one piece. I've been wanting to get mine done but haven't due to lacking funds and the extra cost of splitting. My guy charges 140 for any size wheels, did a stunning job on my Volk drag wheels, ill stick some pics up of them and these split rims when done. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 22, 2010 Author Share Posted February 22, 2010 nice rims jamie look forward to seeing them coated, they you track rims (oz racing?) They was on the na when i got it, just gonna clean em up and keep as spares i think unless i get a good offer Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 22, 2010 Share Posted February 22, 2010 oh very nice anyway, look forward to the pics Quote Link to comment Share on other sites More sharing options...
