krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 They are the wrong springs. DNK, if it lifts 2 inches fairly easily but won't compress it's probably dampers set up for drifting with a huge amount of bump in them. Wrong? Those NA's are wrong? I bought them from the user here and he said those are NA fronts? So what are they? Can you please confirm that NA springs should fit TT shocks with no problem? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2010 Share Posted August 3, 2010 If the lower spring tails don't fit the seats properly they are wrong. Link to comment Share on other sites More sharing options...
krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 If the lower spring tails don't fit the seats properly they are wrong. great... so anybody here with proper front NA springs for sale? Link to comment Share on other sites More sharing options...
krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 I just realized I got them from Keron... is that possible that he made a mistake? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2010 Share Posted August 3, 2010 OK, top photo, that's a rear damper with a correctly fitting stock Toyota rear spring on it. Below is a loose front spring that's not an OE Toyota one, can you put the original Toyota front spring alongside it and take another picture? the loose spring looks like an aftermarket one, far stiffer than an OE front. with a different tail on the lower end of the spring. Link to comment Share on other sites More sharing options...
krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 OK, top photo, that's a rear damper with a correctly fitting stock Toyota rear spring on it. Below is a loose front spring that's not an OE Toyota one, can you put the original Toyota front spring alongside it and take another picture? the loose spring looks like an aftermarket one, far stiffer than an OE front. with a different tail on the lower end of the spring. give me a minute... Link to comment Share on other sites More sharing options...
krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 http://img707.imageshack.us/img707/7584/img0470lu.jpg http://img834.imageshack.us/img834/1891/img0471l.jpg Uploaded with ImageShack.us http://img580.imageshack.us/img580/2701/img0472l.jpg http://img828.imageshack.us/img828/3126/img0473f.jpg Uploaded with ImageShack.us SO ? Link to comment Share on other sites More sharing options...
krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 Chris...? Whats your final opinion? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2010 Share Posted August 3, 2010 They don't look to have the right pigtails on the lower end to me, they should sit as the stock ones. Link to comment Share on other sites More sharing options...
krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 They don't look to have the right pigtails on the lower end to me, they should sit as the stock ones. So they definitely arent oem toyota NA's? Keron wrote to me that they were fitted on KYB AGX, but he thought they are oem ones Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2010 Share Posted August 3, 2010 You have some OEM ones there, you can see they have different ends.... I can't really say any more than that. Link to comment Share on other sites More sharing options...
krisso_pl Posted August 3, 2010 Share Posted August 3, 2010 (edited) You have some OEM ones there, you can see they have different ends.... I can't really say any more than that. Ok, so Ill try to ask other way- I understand that the one on the shock is oem TT spring like the shock. The one loose spring maybe is oem but have a different end and wont fit tight on the shock seat. So-if I want to fit NA spring on that TT shock I need to buy another set of springs with proper ends...yes? Sorry for dumb question but I want to understand it well And last- whats up with those colors? what color goes on what side? Edited August 3, 2010 by krisso_pl (see edit history) Link to comment Share on other sites More sharing options...
krisso_pl Posted August 23, 2010 Share Posted August 23, 2010 ok I got a set of proper shocks and springs now and going to put them together so repeating a question from above- any suggestions? Whats up with those colors and what spring and shock is left and right? Link to comment Share on other sites More sharing options...
krisso_pl Posted October 9, 2010 Share Posted October 9, 2010 So, I havent got time to install parts and am going to install them on monday but decided to ask all of you if I have proper parts. I habe bought may parts from various traders here and abroad and many of them appeared to be not proper ones like aftermarket spring instead of oem NAs etc. To remind you - I want to install TT shocks with NA springs on front and TT/NA shocks (I was told they are the same) with TT springs on rear. And here is what I have: Those should be rear TT shocks with TT springs. Part number is 48530-14360 http://img38.imageshack.us/img38/6766/img0482xl.th.jpg Those should be front TT shocks with TT springs Part number is 48510-1414670 http://img820.imageshack.us/img820/8343/img0484t.th.jpg And those should be front NA springs. http://img801.imageshack.us/img801/7438/img0487s.th.jpg http://img801.imageshack.us/img801/351/img0488r.th.jpg So please tell me-do I have proper parts and can put them together and install on car? Link to comment Share on other sites More sharing options...
krisso_pl Posted October 9, 2010 Share Posted October 9, 2010 Anybody? Link to comment Share on other sites More sharing options...
krisso_pl Posted October 10, 2010 Share Posted October 10, 2010 Hey, anybody here with useful info? Link to comment Share on other sites More sharing options...
jackso11 Posted October 13, 2010 Share Posted October 13, 2010 I gave up reading this, got too confusing with how many spring you have. End line is if it doesn't fit its not right. simple Link to comment Share on other sites More sharing options...
Thomas_germany Posted October 14, 2010 Share Posted October 14, 2010 Very confusing. I think, you had proper springs in the first place. I took out my stock NA-springs and the looked the same. I told you that on SF.com, already. The last picture you posted shows a spring, that looks like my NA-springs. If you still don't know if you got the right part, I suggest, you go to a local toyota dealer and order NA-springs and shocks. You just need the part no. Try to find them on toyodiy.com. But I guess, the toyota dealer will give you the same parts you already got. Thomas Link to comment Share on other sites More sharing options...
krisso_pl Posted October 15, 2010 Share Posted October 15, 2010 Very confusing. I think, you had proper springs in the first place. I took out my stock NA-springs and the looked the same. I told you that on SF.com, already. The last picture you posted shows a spring, that looks like my NA-springs. If you still don't know if you got the right part, I suggest, you go to a local toyota dealer and order NA-springs and shocks. You just need the part no. Try to find them on toyodiy.com. But I guess, the toyota dealer will give you the same parts you already got. Thomas Are you talking about that first set of springs couple months ago? Chris and Keron told me that these are some aftermarket springs, definitely not OEM springs. One from the picture from last post seems to be proper NA Link to comment Share on other sites More sharing options...
