T2 MSW Posted February 21, 2010 Share Posted February 21, 2010 After some spares to continue diagnosing an issue. After a CPS sensor both the cam sensors and a TPS sensor if anyone has one. If anyone can lend me a known working DLI that would be greatly appreciated too. Cheers p.s does anyone know if you change the TPS sensor do you have to recalibrate the AEM? Link to comment Share on other sites More sharing options...
Kev.O Posted February 21, 2010 Share Posted February 21, 2010 Terminator is sending me a cam sensor as my clip is broken but works fine. You're more than welcome to my old one if you want it? Edit: Swampy442 also has one for sale. Link to comment Share on other sites More sharing options...
T2 MSW Posted February 21, 2010 Author Share Posted February 21, 2010 For testing Kev that would be perfect. Ill cover postage if you could put it in the post for me? Is it the front or rear cam sensor? Link to comment Share on other sites More sharing options...
Kev.O Posted February 21, 2010 Share Posted February 21, 2010 That's fine. It's the front one. I've just checked and the front and rear sensors look identical Link to comment Share on other sites More sharing options...
T2 MSW Posted February 21, 2010 Author Share Posted February 21, 2010 Cool,Ill PM you an address, just let me know how much the postage was and ill send you the money. Link to comment Share on other sites More sharing options...
Kev.O Posted February 21, 2010 Share Posted February 21, 2010 Don't worry about the postage Link to comment Share on other sites More sharing options...
Swampy442 Posted February 21, 2010 Share Posted February 21, 2010 If youre stuck as Kev said Ive got one. I may also have a crank sensor but Ill have to get back to you on that one. Link to comment Share on other sites More sharing options...
T2 MSW Posted February 21, 2010 Author Share Posted February 21, 2010 If you can let me know on the cps that would be cool Link to comment Share on other sites More sharing options...
T2 MSW Posted February 22, 2010 Author Share Posted February 22, 2010 Rather than starting a new thread does anyone know the part number of a TPS sensor? Cheers Link to comment Share on other sites More sharing options...
Kirk Posted February 22, 2010 Share Posted February 22, 2010 Why not just ask me nicely and ill ring phil in morning for a price? Link to comment Share on other sites More sharing options...
T2 MSW Posted February 22, 2010 Author Share Posted February 22, 2010 If you can get me prices on Cams, TPS and CPS sensors, that would be ace Link to comment Share on other sites More sharing options...
T2 MSW Posted February 25, 2010 Author Share Posted February 25, 2010 Bump anyone?? Link to comment Share on other sites More sharing options...
absz Posted February 25, 2010 Share Posted February 25, 2010 Will proberly work out cheaper if you have a full diagnostic check done on the car using a scope than changing sensors. can't see cam/crank sensors giving you high boost misfires. if it was me i will do voltage drop testing on the ignition and injector circuits first before changing anything. its quite hard guessiing what is causing you a misfire without having done ALL basic testing first. Link to comment Share on other sites More sharing options...
RobSheffield Posted February 25, 2010 Share Posted February 25, 2010 If you change the TPS or move it i believe it still needs recalibrating in AEM. Link to comment Share on other sites More sharing options...
T2 MSW Posted February 25, 2010 Author Share Posted February 25, 2010 Will proberly work out cheaper if you have a full diagnostic check done on the car using a scope than changing sensors. can't see cam/crank sensors giving you high boost misfires. if it was me i will do voltage drop testing on the ignition and injector circuits first before changing anything. its quite hard guessiing what is causing you a misfire without having done ALL basic testing first. Was either looking for cheap second hand parts or to borrow the parts. If simple things like sensors plugs, injector plugs etc etc dont work then it will be going to someone who knows more than I do Link to comment Share on other sites More sharing options...
T2 MSW Posted February 25, 2010 Author Share Posted February 25, 2010 If you change the TPS or move it i believe it still needs recalibrating in AEM. Cheers Rob Link to comment Share on other sites More sharing options...
Kev.O Posted February 25, 2010 Share Posted February 25, 2010 Hopefully you should receive the cam sensor tomorrow Mike Link to comment Share on other sites More sharing options...
absz Posted February 25, 2010 Share Posted February 25, 2010 Was either looking for cheap second hand parts or to borrow the parts. If simple things like sensors plugs, injector plugs etc etc dont work then it will be going to someone who knows more than I do IF you would like to borrow any sensors then just pm me what you require i'll see what i can do:) Link to comment Share on other sites More sharing options...
T2 MSW Posted February 25, 2010 Author Share Posted February 25, 2010 Hopefully you should receive the cam sensor tomorrow Mike Cheers Fella, much appreciated Link to comment Share on other sites More sharing options...
