kaahari Posted February 21, 2010 Share Posted February 21, 2010 Hi! I hope one simple question about ignition! If you change your turbos (for example stock twins) to a small less heat producing single AND only use same maximum boost pressure temporarely (for example 0.8bar), does it have effect to ignition map over 4000rpm? (when stocks working paraller). More fuel is needed but how is ignition? I am just trying to understand this thing in theory because i have to move my car at spring 2-3 weeks due work and can`t get it mapped sooner... Sorry about bad english Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 21, 2010 Share Posted February 21, 2010 I think i understand your question. You want to move the car without it being mapped? You can, but its far simpler not to boost than to worry about any damage you might do. Just drive wherever you have to, but dont go to full throttle, take it easy. Your English is better than most of our members Quote Link to comment Share on other sites More sharing options...
kaahari Posted February 21, 2010 Author Share Posted February 21, 2010 (edited) Actually.. no more simplified: I want to know how heat of pressurized air (in turbo engine) have effect to timing , assuming afr:s are same (for example 11:1) More heat = must retard timing? Less heat = keep same timing? more advance? retard timing? Just like to know how it goes in theory Edited February 21, 2010 by kaahari typos... (see edit history) Quote Link to comment Share on other sites More sharing options...
