Rough idling/No power.
Guest Lizzy Borden
Guest Lizzy Borden
Hi to all.
New member with a problem.
When i start my car (TT) it fires up normally and runs smoothly. As it warms up it begins to misfire badly. This is more evident if you apply the throttle quickly when stationary. It's pretty much undriveable under any load.
Things i've tried;
1. New coil packs
2. New plugs
3. New coil pack plugs (old ones where baked)
4. Swapped ignitor
5. swapped MAP sensor
6. Discon. FCD
Any help would be greatly appreciated.
Cheers in advance.
Gary.
Guest Lizzy Borden
Crank sensor? TPS? Its a Soarer innit?
Rumbled lol Yes it's a 1jz.
No it's not been stood. No codes coming out.
What resistance is the crank sensor normally?
I'll swap out the o2 sensor and try again. Tps hasn't been moved.
This started after i changed the coil pack plugs for new but i've checked and double checked those.
Guest Lizzy Borden
Today i swapped out the O2 sensor and the coolant (ecu) sensor, and the ECU itself. Still there:thumbdown:
After another run it sounds like the burble you get from the auto box retarding the timing in 'on boost' changes.
It only happens on boost or when revved quickly from idle.
All the injectors sound ok.
Gary.
is the missfire regular like droping one cyl if so you could get someone to rev it while you look and the coil packs etc in the dark to see if its tracking to earth somewhere, might help?
good luck regards chris.
Guest Lizzy Borden
have you cleaned your fuel/air regulator valve this what was happening on my saxo cleaned the valve and now runs smooth
Not familiar with that part on a 1jz bud?
Do you mean the idle control valve (ICV)?
Edited by Lizzy Borden (see edit history)
