Problem with son's Fiesta
CJ
My son has sent me a txt asking for advice on a problem he has with his P reg 1.1 Fiesta.
His problems started after he did an emergency stop a week or so ago. Almost immediately after (although this may be a coincidence) the car started to miss and lose power.
His text says:
"The engine feels like it is going to cut out when idling. There is hardly any power whgen I put my fot down on the accelerator. The engine is missing when idling and the engine is shaking. The exhaust is also blowing. If I turn the lights on or anything electrical, the revs drop".
I told him to check the plugs, leads and coil. He changed these but to no avail. My guess is that there is a bad earth - although I dont profess to be a mechanic.
Any thoughts?
No seen it for years, but the brake sevo's used to leak/split at the joint(air leak)...disconnect the vac pipe to the sevo and block off with your thumb and see how it runs then....thats block off the pipe not the sevo.
If not other probs could be d.i.s pack...plug lead, or just a simple plug gone down?
