halllon Posted February 18, 2010 Share Posted February 18, 2010 Hey guys, I want to remove the oil filter bracket and the water-to-oil heat exchanger/preheater entirely and bolt the oil cooler/filter relocator takeoff straight to the block. Part ID 15671 is the bracket I want to remove: http://www.toyodiy.com/parts/diag_1iTxUYE.png However, I need a shorter bolt to mount the filter relocator directly to the block. Does anyone now if the double threaded bolt from the NA filter bracket will fit? The double threaded bolt is visible in the lower part of this pic (it's the one that the filter bolts to): http://www.toyodiy.com/parts/diag_1iTxUY3.png It doesn't have it's own part number, so I'll probably have to get the entire oil filter bracket from an NA to get just the bolt. Will this bolt fit? If not, where can I get a double threaded, hollow bolt that will bolt straight to the block and filter and have the correct length? Cheers in advance! Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 19, 2010 Share Posted February 19, 2010 Have a read through this think barny did similar thing http://www.mkivsupra.net/vbb/showthread.php?t=203331 Quote Link to comment Share on other sites More sharing options...
