Turbo stalling and autos...
Matt Harwood
I'm hoping some of you techy guys can help here. I don't know if I have a problem or not...
Recently, I have become more aware of what I think is turbo stalling.
If I were to pull out of a junction sharpish, (or overtake something), if I then back off the throttle a little at around 3500 rpm, the autobox changes up a gear and I get a deep drone from the exhaust. At the same time, the turbo pressure drops to around zero. This only lasts about a second before the boost pressure stabilises, the drone fades away, and I can feel the engine is ready to go again.
Does that make sense? - I assume it's not supposed to happen as I believe this is not good for the turbos.
Any suggestions?
No probs. I can't say when I noticed this started to happen though.
The car is a 94 TT auto J-spec.
Decatted, (both) with restrictor plate
TRL VFCC
HKS Hiper
HKS R-type intercooler and hardpipes
Iridium plugs
TRD panel filter
Blitz boost controller
It was definatly doing it before these mods.
Walbro high pressure fuel pump
FSE fuel pressure regulator
HKS SSQV
Any clues?
Matt
I've noticed similar things and was also wondering what was the cause.
On an overtaking move I sometimes have a situation where the 'box changes up whilst on full boost and the power seems to drop for half a second, almost like the engine is catching a breath, then it comes back and keeps going.
This doesn't always happen, most of the time the engine delivers a fairly smooth and constant stream of power during the change.
Jules
Guest Martin F
Well it's a little hard to diagnose these sorts of things without experiencing it. But my guess would be the HKS BOV or a boost leak. I know you say this was happening before you fitted the BOV, but the description you give seems like a BOV that's not reacting properly.
Bit hard to do at a distance.
I fitted the HKS one as a suggestion to cure the problem. I've been told that the BOV can be adjusted but I don't think this will help as the problem happens while I'm still on the throttle.
The deep 'drone' from the exhaust sounds to me like the gearbox retarding the ignition, as it should do, and sounds like normal operation to me. The exhaust note normally drops, 'farts' a bit, and then goes back to normal after the gear change.
Theres always going to be some release of boost pressure between shifts.. generally its not noticeable, but with an aftermarket BOV it may be exaggerating it a bit. Dont forget that the gearbox retards the ignition.. you cant expect the turbo to still be producing max boost during this. Your description sounds like normal operation.
On an auto i'd personally stick to the stock BOV, as autos do funny things to boost pressure when changing.. probably most aftermarket BOV's are made for on/off boost pressure that you get with a manual.
PS im probably technically incorrect, but it kinda makes sense.. i think, maybe...
I don't want to start a rumour here about em, but I'm sure I've read before that FSE valves are unreliable - can anyone back me up on that? Loss of power could be a mixture problem - my car felt godawful as I came on and off boost a while back, it turned out the pressure hose to the fuel pressure regulator had blown off and fuel pressure wasn't increasing with boost.
Under full throttle it's fine. It only happens at part throttle, ie going from half throttle up to 3500 rpm then releasing to quater throttle, the box changes gear, boost goes from 0.6 bar to zero for a second, (if that), then back to about 0.3, (due to the less amount of throttle).
While the boost has dropped you can hear a very prominent deep drone coming from the engine/exhaust before things rectify themselves.
Could be my irratic driving style I suppose :rolleyes:
Matt, that definately sounds like normal operation caused by the gearbox retarding the ignition.. its meant to do it to allow for smoother changes.. its not noticeable with a stock exhaust but a decatted or aftermarket exhaust willl make the noise. the change in the ignition timing will also drop the boost pressure.
Is it less noticeable with the 'pwr' button pressed on the gearbox?.. this normally cancels the igition feature of the gearbox.
Matt,
I've always had this on my car....asked the question before aswell.
I'll try to do it again tomorrow, but I think since I replaced my BOV with a recirc stock bov its stopped happening (as often as it did)
I would guess its an air starvation/flow thing due to the loss of recirculation.
Let me try it tomorrow and let you know.
Mines a 6spd as you know and always used to do it at about the same RPM - I'd accelerate to a ton then ease off and the 'zust note drops suddenly. I apply the clutch let the revs drop - rev it up and hey presto the car sounds normal again....
It might be caused by the sequential system. IanC understands the flow etc quite well might be worth asking him to think about it.
I think it is A turbo stalling. God knows how it effects egt's but I tend to "sort" the proble straight away to avoid issues!
Originally posted by adi
although i cant remember if the mkiv box has a power button.
Is that like Michael Knights Turbo boost button :rolleyes: Looks like you and Martin were on the right track. Isn't the power button the same as the manu button?
Paul, I'm starting to think that its a common thing but my only concern was that I can't remember if it used to do it and I've become more aware of it recently. Perhaps more noticable due to the Hiper.
