reeceu Posted February 17, 2010 Share Posted February 17, 2010 hello guys i am in need of a drivers side rear caliper and cannot find one to hand at the minute and it is needed asap. i have found a toyota camry rear caliper which says it will fit a supra but i was just going to double check with you all that it will either fit or not?!?!?!? cheers Link to comment Share on other sites More sharing options...
Guigsy Posted February 17, 2010 Share Posted February 17, 2010 let me get this right... your going to fit different calipers on one corner of the car to the others? im no expert but thats sounds a bit dangerous. If its a jspec rear caliper you need im sure keron or silverstone garrage can get you one. Link to comment Share on other sites More sharing options...
reeceu Posted February 17, 2010 Author Share Posted February 17, 2010 no i was wondering if the camry was using the same caliper as my supra so it would be a straight swap, if its not the same caliper i will not use it. cheers Link to comment Share on other sites More sharing options...
swich Posted February 17, 2010 Share Posted February 17, 2010 your best bet is to talk to someone on the US owners club Link to comment Share on other sites More sharing options...
merckx Posted February 17, 2010 Share Posted February 17, 2010 hello guys i am in need of a drivers side rear caliper Keron may have what you need. http://www.mkivsupra.net/vbb/showthread.php?t=176741&highlight=caliper Link to comment Share on other sites More sharing options...
