Genuine bodykit parts - quality question.
supra_aero
I have a question...
Do genuine front bumpers (or kit parts in generally for that matter) still crack when hit by stones and low kerbs etc.
The genuine supra bumper has a bit of a rubbery plastic give. So it won't crack so easily if at all generally speaking.
Would a genuine Do luck front or top secret etc. have the same rubbery plastic give/feel? Or is it still brittle fibreglass like replicas and its the fitment you are paying for?
I had a genuine VS front bumper on my Supra before going for a TS front - replica.
I did not see a big difference in material quality, the TS replica is even heavier than the VS was. But as you pointed out, fitment was way better on the genuine one.
I had a small crack on the genuine VS when I had to pass a big bump ... so they aren't really what you can call flexible :)
Luc
Guest SupraGTE
glass fibre will always be glassfibre, abs or the stuff some erebuni things are made of is a better option, would love that rieger would make a kit for supra in abs :)
There is one aftermarket bumper made from plastic. I think it's the stillen, no match for the looks of the Do-luck in my opinion.
But like said, a genuine won't hold up any better than a replica.
That's a pity. They'd be worth their weight in gold if they were more absorbent of hits and bumps like the standard supra bumper.
Just planning my next project :sly:
tx
Guest SupraGTE
:) the worst and most expensive bodykit i ever fitted was this
fitted the 8pcs body kit and when i opened the exhaust box i was going to cry :(
it was only 2 small 10inch end pieces(endpipes) , and need to cut the OE exhaust and slide the over
http://www.vemiri.com/listing.php?cat=range_rover_sport
and it cracked many places in a short time and brackets fell of etc etc
2 weeks later fitted the full ABT kit to Q7 to Janne ahonens Q7 and it fitted like a dream even with all overfenders it looked like a nightmare to fit ehen when opened the package,
so even the most expensive can be a disapointment
like tricky said both abs and glassfibre has it positive and negative sides
