The Raven Posted February 17, 2010 Share Posted February 17, 2010 Same problems with mine, both sides. Are there any drainage holes that can become blocked?? No mate, just worn 15 year old rubber Quote Link to comment Share on other sites More sharing options...
deathmonkey Posted February 17, 2010 Share Posted February 17, 2010 Not to sound stupid - but people who have these problems - do you take it off, put it back on again, drive around a bit and re-tighten? Seems to solve problems any time I've had a leak. I've had say 2 leaks since I've had the car, did the above and it disappeared. Quote Link to comment Share on other sites More sharing options...
Se7eN Posted February 17, 2010 Share Posted February 17, 2010 I have tried refitting the roof and its still the same. I know what you mean though, having the car on flat ground when you put the roof back on can help with the fit. Quote Link to comment Share on other sites More sharing options...
Terminator Posted February 17, 2010 Share Posted February 17, 2010 Rubber looses its mechanical properties when exposed to UV and Ozone, it is not surprising some roof panels leak. New seals sound like the best and not that expensive fix. Give it a few years and we will start seeing window seals failing. Quote Link to comment Share on other sites More sharing options...
Gambit Posted February 18, 2010 Share Posted February 18, 2010 No mate, just worn 15 year old rubber Actually there is, it runs down the front pillars. But look at the door side rubber next time it rains, if you can see the water has run between the rubber and the window.... It's not the drains. Quote Link to comment Share on other sites More sharing options...
trebor69 Posted February 18, 2010 Share Posted February 18, 2010 Main reason i chose a hardtop , i only looked at one aero and the inside was soaking . Quote Link to comment Share on other sites More sharing options...
Gambit Posted February 20, 2010 Share Posted February 20, 2010 Main reason i chose a hardtop , i only looked at one aero and the inside was soaking . What, you assumed it happens to all aerotops and decided against one. I don't think Toyota sold them as new thinking "It leaks, oh well!" I'm sure I speak for all aero's when I say, get a nice warm sunny day, take the roof off, drop the windows and your in driving heaven! Thomas Magnum for the win! Just need to buy me a stick on tash. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted February 20, 2010 Share Posted February 20, 2010 I already have the chest hair and medallion on a chain, and getting that roof off, windows down and the bpu tt roar on the open road is just the best! Especially through the tunnels. Wow! My roof doesn't leak, and it's parked outside at all times (unfortunately). Quote Link to comment Share on other sites More sharing options...
krisso_pl Posted May 19, 2010 Share Posted May 19, 2010 Can someone please tell me where to get 62383-14030 WEATHERSTRIP? I consider ordering from US and want to compare prices Mine targa is leaking like hell and I believe its caused by old seal. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 19, 2010 Share Posted May 19, 2010 (edited) from what i remember they are £40 a seal from Nic *EDIT* ah well wrong again Hi Andrew I would need to order these, order tiem would be around 4-5 weeks, plus 5-7 days postage to UK WEATHERSTRIP, ROOF SIDE RAIL, LH = £31 each including postage WEATHERSTRIP, ROOF SIDE RAIL, RH = £31 each including postage WEATHERSTRIP, REMOVABLE ROOF, FRONT = £35 each including postage WEATHERSTRIP, REMOVABLE ROOF, REAR = £35 each including postage cheers Nic Edited May 19, 2010 by supra steveo (see edit history) Quote Link to comment Share on other sites More sharing options...
krisso_pl Posted May 19, 2010 Share Posted May 19, 2010 So I have to contact Nic yes? What are those other parts? Removable roof front and reaf I know but what are roof side rail - seals on the targa side? from what i remember they are £40 a seal from Nic *EDIT* ah well wrong again Hi Andrew I would need to order these, order tiem would be around 4-5 weeks, plus 5-7 days postage to UK WEATHERSTRIP, ROOF SIDE RAIL, LH = £31 each including postage WEATHERSTRIP, ROOF SIDE RAIL, RH = £31 each including postage WEATHERSTRIP, REMOVABLE ROOF, FRONT = £35 each including postage WEATHERSTRIP, REMOVABLE ROOF, REAR = £35 each including postage cheers Nic Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 20, 2010 Author Share Posted May 20, 2010 no I think that is from an old post, Nic is not trading at the moment. Quote Link to comment Share on other sites More sharing options...
krisso_pl Posted May 20, 2010 Share Posted May 20, 2010 Mates, ive talked to steve and im not satisfied- he told me the seal is for 74L. Nic is unable to help me right now because of the health problems. Who is Mr.T? Where else can I find that seal in good price like 31L...? Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted May 20, 2010 Share Posted May 20, 2010 this was my fear in buying a aero top sup so didnt bother in the end Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 20, 2010 Author Share Posted May 20, 2010 I need the new weatherstrips too, but have not bothered calling steve as I guessed it would be around that price. Mr.T = Toyota. Bes solution I found....find the area the seal is leaking, lift it up and clean underneath, clear silicone under the strip, stick it down. No more leaks. Not ideal but it works until someone comes up with a cheap place to buy them. I found a place online but they won't post outside the US. $45. I told them I would organise UPS to pick it up, they said no. Quote Link to comment Share on other sites More sharing options...
krisso_pl Posted May 20, 2010 Share Posted May 20, 2010 I love having an aerotop and nothing can replace a sunny day and the wind blowing thru your hair:) but targa means more rubber, and more rubber means need of replacing. Thats all. So...anybody...Please... Where can I order seal for 31L or where to contact misterious Mr.T...? Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 20, 2010 Author Share Posted May 20, 2010 Mr.T = TOYOTA !! Quote Link to comment Share on other sites More sharing options...
krisso_pl Posted May 20, 2010 Share Posted May 20, 2010 ok, so there is no way to buy that in good price and 74L is cheapest price for a Longin prace of rubber? Im going to order i from US. Its 42$ and 40$ shipping to my house. Thanks for all the answers;) I need the new weatherstrips too, but have not bothered calling steve as I guessed it would be around that price. Mr.T = Toyota. Bes solution I found....find the area the seal is leaking, lift it up and clean underneath, clear silicone under the strip, stick it down. No more leaks. Not ideal but it works until someone comes up with a cheap place to buy them. I found a place online but they won't post outside the US. $45. I told them I would organise UPS to pick it up, they said no. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 20, 2010 Author Share Posted May 20, 2010 where did you find a place that will ship to the UK? I want to buy one too! Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 20, 2010 Author Share Posted May 20, 2010 also, you realise there are 4 strips... Quote Link to comment Share on other sites More sharing options...
krisso_pl Posted May 20, 2010 Share Posted May 20, 2010 also, you realise there are 4 strips... Im ordering one,front piece that goes around windshield and a-pillars. Others seem to be fine on my car. Im ordering from US Toyota Elmhurst-Curt Aigner. Shipping is to poland but i think it shouldnt be a problem to ship it tu UK? Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 21, 2010 Author Share Posted May 21, 2010 Just an idea, but maybe a group buy could be set up for these? I bet a lot of us Aerotop owners could do with a set of new seals! Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted May 21, 2010 Share Posted May 21, 2010 (edited) Just an idea, but maybe a group buy could be set up for these? I bet a lot of us Aerotop owners could do with a set of new seals! I think you'll find that the official name for that, is a harem of seals, but it's a very good idea. Edited May 21, 2010 by AndrewOW (see edit history) Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 21, 2010 Author Share Posted May 21, 2010 harem of seals. Yup, lets do a group buy of harey strips. I need all 4 Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 21, 2010 Share Posted May 21, 2010 i may as well replace them too or i could wait till i am ready to have the car sprayed then do it after that Quote Link to comment Share on other sites More sharing options...
