miko_supra Posted February 16, 2010 Share Posted February 16, 2010 I want to have a go at replacing all of my rigid brake lines. I will be using copper nickle pipe and making it all myself as apposed to using toyota parts. Just wondering if anyone has done this before and has any advice... Quote Link to comment Share on other sites More sharing options...
Kirk Posted February 16, 2010 Share Posted February 16, 2010 Get a good flaring tool kit to make your life easy. I have 1 which sits into a bench vice with mutliple sized flare nipples and works a charm Quote Link to comment Share on other sites More sharing options...
Terminator Posted February 25, 2010 Share Posted February 25, 2010 Done it on many cars, you need male and female fittings, flaring tool as mentioned, portable hand held version is useful as you can use it under the car. I use an 6mm micro bore pipe bender to get smooth tight curves without the risk the tube collapsing. Quote Link to comment Share on other sites More sharing options...
