Smoking exhaust
Attero
The exhaust on my n/a is smoking (see pic). Is this something to be worried about.
I haven't been particuarly worried about it because it hasn't seemed to make an effect to the car overall (yet) but I would just like to know if anyone has had this problem before.
It's just a continuous white puff of smoke that seems to die down slightly once the car has warmed up a bit but not entirely.
http://img246.imageshack.us/img246/8333/exhaustsmoke.jpg
Guest buster1375
My car has got the same problem, the next thing i'm going to do is get a compression check done as my car overheated recently due to fluid leak from the heater matrix.
Could it maybe be burning oil? If its not its almost certainly head gaskets failure, have a look for oil in the water, a cream substance under the oil filler cap, or on the dip stick if you see any of that its most probably that
  • 2 weeks later...
if it is smoke, check your idle-up valve for the power steering, the vacuum pipes are linked into the Intake Manifold and can draw power steering steering fluid into the manifold.
