DannoSupra Posted February 15, 2010 Share Posted February 15, 2010 Any of you experienced an N/A with trouble starting like this? It's a 1995 SZ Manual. Done about 120kms. It just cranks and cranks like its got no fuel. But it has, and fuel pump primes on ingition. I've had to disconnect fuel pump, crank it for a bit, and connect it up and she'll fire up and run fine! Anyone had an N/A flood before? It's happening more and more after it's been raining Thanks Quote Link to comment Share on other sites More sharing options...
Dave Posted February 15, 2010 Share Posted February 15, 2010 first thing i would do is reset the ecu .disconnect the battery for an hour then reconnect. im not sure if you can check for a fault code, someone with more know how than me will answer that Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted February 18, 2010 Author Share Posted February 18, 2010 The battery has been off for an hour or so when i repaired the starter motor. Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 18, 2010 Share Posted February 18, 2010 An hour?! About 10 seconds should do Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted February 18, 2010 Author Share Posted February 18, 2010 An hour?! About 10 seconds should do Yeah, was just saying the battery has been off for an hour or so when i did the starter motor, last thing i want is the starter live shorting on me Its had a full service about 2-3 months ago too. Maybe Dizzy Cap is starting too fail, causing not an efficient enough spark to start the car and it's just flooding Quote Link to comment Share on other sites More sharing options...
