No heater control functions at all?
Chris Wilson
Got a J-Spec TT here which has been connected up to a slave battery the wrong way round (wrong polarity). LOTS of things have blown, and been sorted, leaving only a none functioning heater to sort. I have checked the fuses in the drivers side kick panel area, and under the bonnet. The owner had a fiddle himself, and had the dash apart. I have checked that there are no plugs left disconnected, but it has an exotic stereo and other gizmos, and the wiring behind the centre dash is a total rats nest. Is the heater stuff controlled by a fuse? Where is it? Has anyone had the heater ecu blow up by wrong polarity jump starting? Anything else to look for? Why can't heaters be less complex, these things are just so OTT ;) ? Thanks.
Edited by Chris Wilson (see edit history)
Go a J-Spec TT here which has been connected up to a slave battery the wrong way round (wrong polarity). LOTS of things have blown, and been sorted, leaving only a none functioning heater to sort. I have checked the fuses in the drivers side kick panel area, and under the bonnet. The owner had a fiddle himself, and had the dash apart. I have checked that there are no plugs left disconnected, but it has an exotic stereo and other gizmos, and the wiring behind the centre dash is a total rats nest. Is the heater stuff controlled by a fuse? Where is it? Has anyone had the heater ecu blow up by wrong polarity jump starting? Anything else to look for? Why can't heaters be less complex, these things are just so OTT ;) ? Thanks.
If you need another heater control thingy whatsit we can send one up to try Chris, if that helps.
I think I have missed the Parcel Force cut off time, would you just send it via your couriers please? Address is:
Chris Wilson
Newbury House
Lower Heath
Shropshire
SY13 2BT
Thanks Dude, let me know what I owe you, cheers.
Just missed my courier too!!!! I'll try and get him to come if not you will get it weds.
