wile e coyote Posted February 14, 2010 Share Posted February 14, 2010 (edited) Not sure if anybody has done this so started a new thread for ref. Please add if you have some your self ENGINE TT Oil Filter: 90915-Y2ZJ3 Cam Belt 13568-49036 Drive/Aux Belt 90916-A2007 Front Crank Seal 9031146001 4Life Red Coolant 08889-08882 Fuel filter T23300-49195 Sensor,oxygen upto sept 97 T89465-19635 Sensor,oxygen from sept 97 T89465-19725 AUTO GEARBOX Strainer oil T35330-50010 005F02 Power stg flu T08886-82025 MISCELLANEOUS Strut Nuts x 6 9017910200 UK SPEC BRAKES 04479-14140 Front Brake Caliper Overhaul Kit 04479-14130 Rear Brake Caliper Overhaul Kit Edited February 15, 2010 by wile e coyote Added (see edit history) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 15, 2010 Author Share Posted February 15, 2010 Any chance we can make this sticky so it does not get lost Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2010 Share Posted February 15, 2010 Plagiarised from elsewhere, not verified, a lot will be LHD: FILTERS: air filter-#17801-07020 fuel filter-#23300-49195 oil filter-#90915-20004 [jap made] pcv valve-#12204-46020[TT] pcv valve-#12204-46030 [NA] pcv grommet-#90480-18001 FLUIDS: automatic-#08886-81015 type-t-iv getrag 6spd-#08885-01306 v160 antifreeze-#00272-1LLAC-01 Toyota Red engine oil- 5w30 or 10w30 differental oil- 75w-90 or equilivent disk brake grease-#08887-80609 WIPER PARTS: blade assy rh-#85212-33011 blade assy lh-#85222-14610 [also works on rh side] blade assy rear-#85242-14020 refill frt rh-#85214-YZZB7 refill frt lh-#85214-YZZB9 refill rear-#85214-YZZB6 arm rh-#85211-14310 arm lh-#85221-14310 arm rear-#85241-14020 TUNE UP PARTS: plugs-#90919-01178 [TT] ND platinum plugs-#90919-01210 [TT] ND iridium plugs-#90919-01168 [NA] ND platinum plugs ngk for bpu-#3330 dist cap-#19101-70020 [NA] dist rotor-#19102-46011 [NA] wires-#90919-21521 [NA] coil-#90919-02205 [TT] coil-#90919-02207 [NA 93.5-97] coil-#90919-02216 [NA 98] coil elec. plug repair-#90980-11246 BELTS: drive belt-#90916-02310[serpentine] drive belt tensioner-#16620-46070 [TT 6spd] drive belt tensioner-#16620-0W025 [NA all /TT auto] timing belt-#13568-49036 BRAKES: frt pads-#04465-14150 [TT for 4pot calipers] frt shims-#04945-14110[TT] frt clips-#04947-14010 [TT] frt pad pins-#90240-06019[TT] rear pads-#04466-14040 [TT] rear shims-#04946-14030 [TT] rear clips-#04948-14010 [TT] rear pad pins-#90240-06017 [TT] frt rotor rh-#43512-14200 [TT] frt rotor lh-#43516-14030 [TT] rear rotors-#42431-14150 [TT] cal kit frt-#04479-14140 [TT] cal kit rear-#04479-14130 [TT] cal assy frt rh-#47730-14260 [TT] cal assy frt lh-#47750-14270 [TT] cal assy rear rh-#47730-14270 [TT] cal assy rear lh-#47750-14280 [TT] frt pads-#04465-14081 [NA and 2pot caliper TT] frt shims-#04945-14010 [NA] frt clips-#04947-24030 [NA] frt cal pins-#47715-24010 [NA] rear pads-#04466-30030 [NA] rear shims-#04946-24010 [NA] rear clips-#04948-50010 [NA] rear cal pins main-#47715-06030 [NA] rear cal pins sub-#47715-06020 [NA] frt rotors-#43512-14190 [NA] rear rotors-#42431-30140 [NA 93.5-95] rear rotors-#42431-30240 [NA 96-98] cal kit frt-#04479-14120 [NA] cal kit rear-#04479-24030 [NA] cal assy frt rh-#47730-24082 [NA 93.5-94] cal assy frt lh-#47750-24082 [NA 93.5-94] cal assy frt rh-#47730-14281-84 [NA 95-98] cal assy frt lh-#47750-14291-84 [NA 95-98] cal assy rear rh-#47730-14240-84 [NA] cal assy rear lh-#47750-14240-84 [NA] WHEEL BEARINGS/SEALS frt axle hub-#43502-30140 frt wheel brg-#90903-63006-77 frt wheel seal-#90311-50008 rear axle hub-#42301-30030 rear wheel brg-#90369-43005-77 rear seal inner-#90311-63001 rear seal outer-#90311-57001 CLUTCH PARTS: pilot brg-#90363-12002-77 [TT-NA] t/o brg-#90903-63001 [TT] t/o brg-#31230-22100 [NA] clutch cover-#31210-14170-84 [TT] clutch cover-#31210-30261-84 [NA] clutch disc-#31250-14190 [TT] clutch disc-#31250-30391-84 [NA] clutch master-#31410-14310 clutch slave-#31470-22120 [NA] clutch slave-#31470-14060 [TT] clutch master kit-#04311-12110 clutch slave kit-#04313-14020 [TT] clutch slave kit-#04313-17010 [NA 93.5-96.5] clutch slave kit-#04313-22030 [NA 96.6-98] clutch fork-#31204-14060 [TT 6spd] clutch fork-#31204-22050 [NA 5spd] ENGINE PARTS: 02 sensor-#89465-19605 cam seals-#90311-40020 crank seal-#90311-46001 rear main seal-#90311-90006 v/c gskt intake-#11213-46020 v/c gskt exhaust-#11214-46011 v/c gskt exhaust-#11214-46030 [NA 98] silicone gasket sealer-#00295-00102 [the black stuff in a tube] pcv hose frt v/c-#12264-46010 [TT] pcv hose rear v/c-#12263-46010 [TT] fuel pump-#23221-46070 [NA 93.5-97] fuel pump-#23221-50060 [NA 98] fuel pump-#23221-46110 [TT] fuel pump brkt-#23206-46160 [TT] fuel pump brkt-#23206-46140 [NA] t-belt ilder-#13505-46041 t-belt tensioner-#13540-46030 t/stat-#90916-03093 t/stat gskt#16325-62010 w/pump-#16100-49837 [NA] w/pump-#16100-49846 [TT] rad cap-#16401-62100 alternator-#27060-46200-84 [TT 6spd] alternator-#27060-46120-84 [TT auto] alternator-#27060-46190-84 [NA 93.5-95.5] alternator-#27060-46050-84 [NA 95.6-98] starter-#28100-46140-84 engine mounts-#12360-46070[93.5-95.4] engine mounts-#12360-46111[95.5-98 improved design] trans mount-#12371-46110 [TT 6spd] trans mount-#12371-46120 [TT auto] trans mount-# 12371-46090[NA 5spd] trans mount-#12371-46020 [NA auto] radiator assy-#16400-46420 [TT 6spd Alumin.type] radiator assy-#16400-46430 [TT auto alumin.type] radiator assy-#16400-46290 [NA 5spd] radiator assy-#16400-46300 [NA auto] short block assy-#11400-49088 [TT] full gskt kit engine-#04111-46094 [TT] BODY PARTS: hatch stay rh-#68950-19895 [w/spoiler] hatch stay lh-#68960-19585 [w/spoiler] hatch rubber stopper-#67293-14051[stops the squeak] screws for above 2ea-#90159-50116 targa roof-#63201-14060 targa mld rh-#63217-14030-C0 targa mld lh-#63218-14020-C0 targa w/strip rh-#62383-14030 targa w/strip lh-#62384-14030 targa headliner-#63312-14050-C0 targa bolts frt-#90901-09004 targa bolt /brkt rear rh#63240-14090[2pc brkt w/bolt] targa bolt/ brkt rear lh#63240-14060 [2pc brkt w/bolt] targa ctr.lock assy-#63203-14100 HELICOIL KIT FOR TARGA BOLTS-#5546.6 [6mm x 1.0] turbo spoiler rear-#76085-14909 frt glass mld-#75533-14190 back glass mld-#75573-14210 floor carpet-#58510-1B171-A0 [ stick/ivory] floor carpet-#58510-1B171-C0 [stick/black] floor carpet-#58510-1B181-A0 [auto/ivory] floor carpet-#58510-1B181-C0 [auto/black] rear lisc.plate nuts-#52121-24020 tonneau cover trunk-#64910-14060-C0 power antenna-#86300-14411 power antenna mast only-#86337-14411[chrome only] ash tray-#74102-14130 [93.5-96] ash tray-#74102-14140 [97-98] ACCESSORIES: front end mask-#00218-14930 mudguards frt-#76095-14010 wheel locks-#00276-14930 floor mats blk/ivory logo-#00200-14930-08 floor mats blk/silver logo-#00200-14930-13 floor mats blk/SE logo-#00200-14950-01 [discontinued] EMBLEMS: gold NA kit -#00211-14950[no "turbo"logo]{discontinued} gold TT kit -#00211-14970 [w/"turbo" logo]{discontinued} gold SE kit-#00211-14954 {discontinued} gold SE logo only-#00211-14953 {discontinued} gold ctr cap logo-#00211-00951 gold ant. nut-#00577-35950 gold "logo"frt-#00211-14956 gold "toyota"-#00211-14951 gold "supra"-#00211-14952 gold "logo"rear-#00211-14957 15th anniv.logos-#00211-14971-01 blk 15th anniv.logos-#00211-14971-28 silver SE side stripes rh-#00211-4R951 SE side stripes lh-#00211-4L951 "turbo"logo -#00016-23940{small brushed Aluminium w/black letters used by Toyota Southeast Distributors.94-95?TT} frt cover "logo" grey-#75314-14010 tailgate "toyota"grey-#75441-14190 tailgate "logo" grey-#75471-14010 tailgate "supra" grey-#75442-14280[93.5-96 TT all NA] tailgate "supra turbo" grey-#75443-14180[97-98 TT] trd 3pack logo-#00602-42601-EMB[carbon fiber style 1"x2.75" "toyota racing development"red letters "TRD" chrome large letters] TRD SPORT PARTS: trd sway bar kit f&r-# 00602-48800-003 trd strut tower brace-#00602-53607-007 trd spring/strut kit-#00602-48000-008 [NA][discontinued] trd spring/strut kit-#00602-48000-009 [TT] [discontinued] trd SS brake lines-#00602-47300-012[discontinued] trd oil filter-#00642-90915-001 trd oil cap-#00602-12108-003 trd air filter-#00642-17801-002[oem style] trd rad cap-#00642-16401-003 trd clutch kit-#00602-31201-010 [TT] trd gen 2 exhaust cat back-#00602-17400-016 [TT] trd fuel pressure regulator-#00643-23280-000 trd brake pads-#00602,00643-XXXXX-XX [all discontinued] trd 10,000 rpm tach-#[all discontinued] DRIVETRAIN: getrag 6spd assy-#33030-0W212 silicone trans pan sealer-#00295-01281 [orange stuff] atm screen filter-#35330-30011 [NA 93.5-97] atm screen filter-#35330-50010 [TT /NA 98] drive shaft-#37100-14810 [TT 6spd] drive shaft-#37100-14820 [TT auto] rear diff pinion seal-#90311-50018 [6spd] rear diff pinion seal-#90311-44005[ TT auto-NA all] rear diff axle seals-#90311-45013 [6spd] rear diff axle seals-#90311-47008 [auto all/NA 5spd] input shaft seal-#90080-31037[TT 6spd] output shaft seal-#90080-31029[TT 6spd] shift rod case seal-#90080-31032[TT 6spd] OIL PRESSURE SENSOR MOD: union bolt-#90401-19008 gasket-#90430-20016 o ring-#90301-68005 EXTERIOR LIGHTING: 3rd stop lamp-#81570-14060[93.5-94] 3rd stop lamp-#81570-14061[95-98] head lamp lh-#81151-1B241 [98 style grey no bulbs] head lamp rh-#81111-1B241 [98 style grey no bulbs] tail lamp lh-#81561-14700 [98 style grey no bulbs] tail lamp rh-#81551-14700 [98 style grey no bulbs] t/s lamp frt rh-#81510-80086 [97-98 clear assy w/bulbs] t/s lamp frt lh-#81520-80086 [97-98 clear assy w/bulbs] t/s frt harness -#81515-14390[97-98 pig tail for aftermarket lamps] turn signal/hazzard flasher-#81980-12070 indicator-#81730-20220 [93.5-96 style indicators in clear]part is actually for the 2003 corolla but perfect fit for supra EXHAUST HARDWARE: lock nuts-#90179-08059 [8mm w/washer for 02 studs/ misc] lock nuts-#90179-10070 [10mm w/washer for studs / misc] bolts-#90105-10023 [ 10mm w/washer for exh pipes] nuts-#94180-41000 [10mm w/washer for exh pipes] studs-#90179-10070 [10mm for most mainfolds/exhaust] INSTRUMENT PANEL BEZELS 97/98 part# 55410-14530 ctr upper part# 55404-14570 lh dash part# 55420-14060 speedo bezel part# 55405-14170 radio/hvac panel part# 58804-14100 6spd shift bezel part# 58804-14110 atm shift bezel part#74232-14121 lh door switch bezel Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 16, 2010 Author Share Posted February 16, 2010 Chris Quote Link to comment Share on other sites More sharing options...
bamboo rocket Posted February 16, 2010 Share Posted February 16, 2010 Hood Scoop Install Here is a list of parts to order: 76181-14900 Bulge, Hood 76182-14010 Guide, Hood Air Intake 76183-14010 Protector Hood Bulge, No. 1 76184-14010 Protector Hood Bulge, No. 2 76187-14010 Retainer, Hood Air Intake Guide, No. 1 (2) 76192-14010 Plate, Hood Bulge 93567-14512 Screws (8) 90179-06058 Nuts (4) 76186-14010 Seal, Hood Air Intake Quote Link to comment Share on other sites More sharing options...
devan Posted February 16, 2010 Share Posted February 16, 2010 Excellent thread idea. Dash Switch Blanks: Pre Facelift: 55537-14020 - Left Blanking Piece 55538-14020 - Right and Centre Blanking Piece Facelift: 55537-14040 - Left Blanking Piece 55538-14030 - Right and Centre Blanking Piece. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 17, 2010 Author Share Posted February 17, 2010 Sticky sticky ? Quote Link to comment Share on other sites More sharing options...
bamboo rocket Posted February 18, 2010 Share Posted February 18, 2010 Sticky sticky ? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 5, 2010 Author Share Posted March 5, 2010 SUSPENSION Front ----- Upper: 48610-19025 Front Upper Arm - RH 48630-19025 Front Upper Arm - LH 48610G Nut for front upper suspension arm RH 48630C Nut for front upper suspension arm LH 4*90209 14007 std part, washer 48610F Bolt for front upper suspension arm RH 48630B Bolt for front upper suspension arm LH Lower: 48068-14080 Front Lower Arm sub assy - RH 48069-14080 Front Lower Arm sub assy - LH 43330L Nut, castle for front lower ball joint RH - does this come with sub assy? 43340B Nut, castle for front lower ball joint LH - does this come with sub assy? 2* 90468 16016 std part, castle nut binder - does this come with sub assy? 2* 48068G Nut for front suspension lower arm RH 2* 48069C Nut for front suspension lower arm LH 4* 90201 16017 std part, washer 2* 48194D Cam, front suspension camber adjust No2 RH 2* 48198D Cam, front suspension camber adjust No2 LH 2* 48657A Stopper, front lower arm bush 2* 48194C Cam, front suspension camber adjust No1 RH 2* 48198C Cam, front suspension camber adjust No1 LH 2* 95622 11200 std part, washer 2* 90170 12036 std part, nut Rear ---- 8* 90201 14020 washer, std part Lower arm (rearmost): 48730-14040 Rear Lower Arm - RH 48740-14070 Rear Lower Arm - LH 2* 48710P Nut, No2 rear lower control arm 2* 48710N Nut, No1 rear lower control arm 48194H Cam, rear suspension camber adjust No2 RH 48198R Cam, rear suspension camber adjust No2 LH 2* 48198H Cam, camber adjust, No2 Lower arm (frontmost): 48710-14110 Rear Arm Assembly RH 48720-xxxxx Rear Arm Assembly LH 2* 90179 12027 std part, nut 2* 48710N Nut, No1 rear lower control arm 2* 48198H Cam, camber adjust, No2 48194G Cam, rear suspension camber adjust, No1 RH 48198G Cam, rear suspension camber adjust, No1 LH Strut rod: 48780A Rod assy, rear 48780A Rod assy, rear 4* 48780C Nut for strut rod 4* 48780B Bolt for strut rod 48725-14070 Bush, rear axle carrier 48725F RH 48725-14070 Bush, rear axle carrier 48725G LH Upper arm: 48770A Arm assy, Upper control, rear RH 48790 Arm assy, Upper control, rear LH 4* 48770D Nut for rear upper control arm 2* 90201 14031 std part, washer 2* 48770F Ring, E for rear upper control arm 2* 48757 Attachment, rear suspension arm 2* 48770H Bolt, rear upper control arm RH 2* 48790B Bolt, rear upper control arm LH Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted October 11, 2010 Share Posted October 11, 2010 now thats a proper thread, thanks for that, very helpful. Quote Link to comment Share on other sites More sharing options...
FireStormNBI Posted October 12, 2010 Share Posted October 12, 2010 part numbers for all toyota.. heres the link.. very useful... http://www.toyodiy.com/parts/ Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 19, 2012 Author Share Posted March 19, 2012 Just reused this to order all my lower wishbones and bolts etc Quote Link to comment Share on other sites More sharing options...
Stevo Posted March 20, 2012 Share Posted March 20, 2012 For anyone that needs the diagram(s) to go with the part numbers, don't forget to check out these sites as well: http://www.utoyot8.com/CatalogComponent.aspx?catalogCode=291430&year=1993 - 1998&modelName=SUPRA http://www.turbosupras.com/pages/en/pages/technical/a80tsrm.htm Quote Link to comment Share on other sites More sharing options...
Camry5Sgte Posted August 28, 2012 Share Posted August 28, 2012 (edited) For anyone that needs the diagram(s) to go with the part numbers, don't forget to check out these sites as well: http://www.utoyot8.com/CatalogComponent.aspx?catalogCode=291430&year=1993 - 1998&modelName=SUPRA http://www.turbosupras.com/pages/en/pages/technical/a80tsrm.htm The first link didn't work for me and the second link is just the manual, it doesn't have the part numbers in it. I am looking for the part number for the screws that hold the passenger side a pillar handle (named the assist grip in the manual). EDIT: found the part number 90159-60084 SCREW Edited August 28, 2012 by Camry5Sgte Found the part number (see edit history) Quote Link to comment Share on other sites More sharing options...
Camry5Sgte Posted August 28, 2012 Share Posted August 28, 2012 (edited) Deleted post Edited August 28, 2012 by Camry5Sgte obsolete (see edit history) Quote Link to comment Share on other sites More sharing options...
rider Posted January 23, 2018 Share Posted January 23, 2018 Resurrecting an old post with a comprehensive list available. Love the prices!supra parts.pdf Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted May 14, 2019 Share Posted May 14, 2019 Can someone please assist me with a rear rubber seal/pug for the rear of the body where the boot/tail gate hinges mount onto the body section pls. The one side has the harness which has its own rubber sleeve and the other side is suppose to have a rubber plug. I checked at Toyota yesterday and didn't win really. Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 14, 2019 Share Posted May 14, 2019 Possibly this 90333-20001 Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted May 15, 2019 Share Posted May 15, 2019 That the flat sticker looking like thing. They showed me that. Similar thing you would find where the door cushion closing rubber stopper would hit against the body but the sticker would be there instead of it just hitting up against the paint work Quote Link to comment Share on other sites More sharing options...
