Lacoste82 Posted February 14, 2010 Share Posted February 14, 2010 Hey all, hope everyone is enjoying a sunny sunday:) I hope someone can help me with a couple of questions, regarding brakes and Spacers! First of all, im thinking about ordering some spacers, need them in 10mm all around. but im not sure which one would fit, as its not like cars with bolts, where one just puts in a spacer and buy longer bolts! I was looking at these, can anyone tell me if they will fit an mkiv? I know it says from 86-98, just want to be sure: http://cgi.ebay.com/ebaymotors/ICHIBA-V1-10MM-WHEEL-SPACER-5X114-3-SUPRA-RAV4-MR-2_W0QQitemZ200370447804QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2ea70265bc Second of all, i need some new brake discs and pads, just need some for normal driving, nothing extraordinary - If anyone could supply me with a link, for a dealership, pref. to the size for a 93 jap spec n/a Thx in advance guys! Link to comment Share on other sites More sharing options...
garethr Posted February 14, 2010 Share Posted February 14, 2010 (edited) Yes, they would fit. The MkIV is also 5x114.3 PCD, 60.1 centre bore, and 12mmx1.5mm wheel nut threads. Assuming that your car has the usual 2-piston/1-piston "J-spec" brakes (and not the 4-piston/2-piston calipers), the front and rear are the same as a Mk1 Lexus GS300 (JZS147), if that makes it easier to find them. Edited February 14, 2010 by garethr (see edit history) Link to comment Share on other sites More sharing options...
RobSheffield Posted February 14, 2010 Share Posted February 14, 2010 Toyota would be a good dealership to try for brake parts. Link to comment Share on other sites More sharing options...
Lacoste82 Posted February 14, 2010 Author Share Posted February 14, 2010 gareth: The reason why im asking, is the fact that ichiba supplies 2 kinds of spacers, a set for a car where the wheel are bolted in with nuts, like these: http://www.ichibausa.com/whspveii.html The other set is for one where the car uses bolts, like this: http://www.ichibausa.com/whspad.html And as u might have noticed, thats enough to confuse me Haha... - Because they supply both kinds for the Supra mkiv, and it says on ebay, the the set for sale is Version 1, the second ones ive linked to! So my question must be, has the supra been made to fit both versions? Rob: Yea, you are right, if it wasnt for the fact that im from Denmark, and the dealership here wants almost 2200 GRP for disc and pads all the way around, and after what ive seen, it can be done cheaper with discs that are just as good :0) Link to comment Share on other sites More sharing options...
Guest aristo Posted February 15, 2010 Share Posted February 15, 2010 Hi there, the version II wheel spacers for the supra are sized 15mm, 20mm, 25mm, Version I Wheel Spacers for the supra are sized 5mm, 10mm, 15mm, 20mm. Link to comment Share on other sites More sharing options...
