J-Spec cam shaft Q?
Vagnum
I was looking on Ebay earlier and came accross a set of used j-spec cams for sale (which have now gone) and the ad said that you can use the EX cam to replace the IN cam so your using 2 EX cams. I've never heard of this before and was wondering if this is right? and if anyone has done it?
Edited by Vagnum (see edit history)
from memory i am sure there is something different about the front of the cams so you cant mix them up
