JamieP Posted November 8, 2010 Share Posted November 8, 2010 Looking good.... Ryan - Is the base map for 2,200 cc Injectors... Will it need much fuel correction to get it to idle properly and read some sort of sensiblish reading for the MOT? 2200cc injectors on a single turbo supra with no cats passing a legit mot? is that even possible? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 8, 2010 Share Posted November 8, 2010 2200cc injectors on a single turbo supra with no cats passing a legit mot? is that even possible? No It'll definately need a cat in. Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 8, 2010 Author Share Posted November 8, 2010 2200cc injectors on a single turbo supra with no cats passing a legit mot? is that even possible? Eeeerrrrrrmmmmmmm :D:D Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 8, 2010 Share Posted November 8, 2010 andy am sure your injectors are 1600cc.. i will speak to ryan ref mot mate Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 8, 2010 Share Posted November 8, 2010 andy am sure your injectors are 1600cc.. i will speak to ryan ref mot mate If they are injector dynamic 2000 then they are 2200cc, same ones going in my car. Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 8, 2010 Author Share Posted November 8, 2010 If they are injector dynamic 2000 then they are 2200cc, same ones going in my car. Pretty sure I ordered ID 2,200cc's will be annoyed if there not TBH Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 8, 2010 Share Posted November 8, 2010 Pretty sure I ordered ID 2,200cc's will be annoyed if there not TBH They are named ID2000, they flow 2000cc at 3 bar and 2200cc at 4 bar. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted November 9, 2010 Share Posted November 9, 2010 Looking good.... Ryan - Is the base map for 2,200 cc Injectors... Will it need much fuel correction to get it to idle properly and read some sort of sensiblish reading for the MOT? The base map is for the ID2000 injectors but dont count on it being anywhere near perfect as it was a rough calculation based on the info i have from them before and the amount of demand your engine will be producing but i had no info on the cams so couldn't really work out what vacuum they will be producing at idle. All i can say is get someone who is good with computers to install the syvecs software of the forum on syvecs.co.uk and then call me Ryan Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted December 5, 2010 Author Share Posted December 5, 2010 Little Update IT's Alive Ryan with Jurgen managed to get it fired up, Theres some sort of wiring issue with the TPS and MAF which Ryan will sort out next week when he comes to collect it for mapping On Wednesday (weather permitting)... So we will see what the car does at SRR and TDI..... Thanks for all involved with all the hard work they've put into the car.... Jurgens team especially Quote Link to comment Share on other sites More sharing options...
davej705 Posted December 5, 2010 Share Posted December 5, 2010 Good news Look forward to seeing the dyno results.make sure you get a vid! Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 5, 2010 Share Posted December 5, 2010 Whats the idle like with the ID2000's mate? good cold starting? Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 5, 2010 Share Posted December 5, 2010 yep the car fired up after some tweeking on the ecu with ryan via phone, there is a feed ecu wire for TPS missing on ecu pin 10, but ryan managed to get it to run by adjusting parameters for car. it was -6 here yesterday and car fired up first time i could not hold the idle due to missing wire (as it was shutting down straight away) but once we changed the the settings the car would fire up and hold to 1000 but now its flooded lol.. i have loads to update on it pics etc , but weather has held a lot of of our work back and most of my time has now been in workshop over last 2 weeks. if weather holds ryan will come on wed for the car to map the thing..(but it think the weather will not be good) once ryan has finished with it we still need to do some work on it. Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 5, 2010 Share Posted December 5, 2010 ticking over it flooded? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 5, 2010 Share Posted December 5, 2010 When is it coming to TDi, its only a couple of mins away from me and I would love to see it Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted December 5, 2010 Author Share Posted December 5, 2010 Should be arround later on this week..fri or sat..will have to check with ryan Quote Link to comment Share on other sites More sharing options...
Josh Posted December 5, 2010 Share Posted December 5, 2010 Looking forward to seeing the pictures/videos Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 5, 2010 Share Posted December 5, 2010 ticking over it flooded? the new solaris ecu was missing a pin feed wire to a sensor or something along them lines (ryan knows better), we fired the car up and then it would cut off this was done around 15 times before the car got flooded. its not a good idea to start and turn off a big single so many times with this amount of fuel going to it, especially when its not mapped so this is why it flooded. ryan just wanted to check the car will fire up. Quote Link to comment Share on other sites More sharing options...
Abz Posted December 6, 2010 Share Posted December 6, 2010 Should be arround later on this week..fri or sat..will have to check with ryan Damn, I am going away tonight or I would have loved to come watch this along with Dean Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 9, 2010 Share Posted December 9, 2010 well here is the pics she is almost done... car now starts and moves a little around the workshop (need ryan to map it lol).. THE NOISE IS INCREDIBLE enjoy the pics. we still need to do following.. -dust downn and tidy up engine bay and polish clean etc.. -paintshop to make car mint 100% -window tints -alarm -finish off ice system and interior trim and once ryan has mapped her , we will get car set up for suspension and geometry etc.. stealth hidden water injection fill up Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 9, 2010 Share Posted December 9, 2010 some more pics Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 9, 2010 Share Posted December 9, 2010 these are last lost pf pics till she back from bodyshop and has all the ice system fitted... damm she is low Quote Link to comment Share on other sites More sharing options...
Westy Posted December 9, 2010 Share Posted December 9, 2010 Looking great Jurgen! Def need to get a couple of vids up when its all finished...need to hear that exhaust! Will there also be an updated spec list!? Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 9, 2010 Share Posted December 9, 2010 Looking great Jurgen! Def need to get a couple of vids up when its all finished...need to hear that exhaust! Will there also be an updated spec list!?yep will do mate Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted December 9, 2010 Author Share Posted December 9, 2010 Really happy on progress Im wondering on how she will do on mapping day Whatever it is .. im sure she will be great fun to drive Thanks Jurgen and Co for all the hard work Quote Link to comment Share on other sites More sharing options...
Luxluc Posted December 9, 2010 Share Posted December 9, 2010 Amazing work. Quote Link to comment Share on other sites More sharing options...
