p3te Posted February 12, 2010 Share Posted February 12, 2010 I’m looking to buy a universal fit hks ssqv bov but was just wondering how these are fitted? Is it just direct fit onto the intercooler pipe work with a weld on flange? Then the thinner hose fitted as normal? Or is there any other way? Quote Link to comment Share on other sites More sharing options...
p3te Posted February 12, 2010 Author Share Posted February 12, 2010 anyone? Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 12, 2010 Share Posted February 12, 2010 The universal one requires a flange to be welded into the intercooler pipe work. Quote Link to comment Share on other sites More sharing options...
p3te Posted February 12, 2010 Author Share Posted February 12, 2010 and is that all thats needed to fit it? 25mm weld on flange? Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 12, 2010 Share Posted February 12, 2010 and is that all thats needed to fit it? 25mm weld on flange? Yep and then just run a vac hose from the top of the dump valve to the manifold and tee it in somewhere. Quote Link to comment Share on other sites More sharing options...
p3te Posted February 12, 2010 Author Share Posted February 12, 2010 nice one cheers Quote Link to comment Share on other sites More sharing options...
p3te Posted February 12, 2010 Author Share Posted February 12, 2010 i see some are steel and some aluminium, does it matter what kind? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 12, 2010 Share Posted February 12, 2010 Depends what you are welding onto Quote Link to comment Share on other sites More sharing options...
p3te Posted February 12, 2010 Author Share Posted February 12, 2010 ah, so steel to steel alu to alu? also looking on ebay there is 50mm 60mm and 65mm flanges? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 12, 2010 Share Posted February 12, 2010 I'm not a welder so I'm only going with what I think here. As far as I remember Ally can be a bit of a bitch to weld, especially to different materials so if your pipes are alloy then it is really your only choice. Steel will be fine to weld onto most materials, some harder than others but more flexible than ally. Quote Link to comment Share on other sites More sharing options...
p3te Posted February 12, 2010 Author Share Posted February 12, 2010 ah ok thx for the info , ill look into it a bit more Quote Link to comment Share on other sites More sharing options...
