abs unit
dcarrter21
  • 4 weeks later...
Guest intrex
does anyone has pictures of the non abs lines where they go and where they connect.
I'm removing my abs and I need to see how on a NA supra the lines are connected
I've done a bit of searching but I can't seem to find any pictures that would help.
I do know that an extra brake pipe is required to facilitate the removal of the ABS.
To be a little more specific its the pipe which runs from the brake master cylinder towards the left hand (near side??) front corner on a non-turbo supra IIRC.
Got that little nugget from Paul Whiffin when I enquired last year.
Still haven't put it to good use yet though.
I dont actually know if the part required is from a car without ABS or any other details of the operation. I certainly would like some guidance on this matter too if at all possible.
My Supra doesn't have ABS, but to retrofit, would require to change both rear hubs, both rear driveshafts, a similar change upfront, (unknown) and lots of wires and sensors and ECU's (unknown) and electronics (unknown).
The plumbing would be the easy bit.
I will do you a favour and give you a tenner for the lot, and expect it to be delivered for that price too.
