Geo Posted August 30, 2010 Author Share Posted August 30, 2010 Bump guys Mine were sitting at 30psi tonight, was out playing again and could really feel the car not right. Get em checked! Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 30, 2010 Share Posted August 30, 2010 It's also worth noting that if your tyres are 20% under-inflated you'll use around 10% more fuel. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted August 30, 2010 Share Posted August 30, 2010 I always check mine when I drive my car every single time I have the car pump Quote Link to comment Share on other sites More sharing options...
geordie82 Posted August 30, 2010 Share Posted August 30, 2010 couldnt agree more, i had 4 new tyres fitted 2 months ago jumped in the car following weekend felt a bit sloppy so pulled into garage probably 400 yards away rear n/s was at 8psi £220 for a new tyre, after less than 30 miles because it wasnt sealed properly and had split, still got a dispute going with bridgstone grrrrrr Quote Link to comment Share on other sites More sharing options...
Wez Posted August 30, 2010 Share Posted August 30, 2010 This is where the tyresure monitors really come into there own, all four pressures and temps right in front of you every time you use the car. I have mine at 36psi front and 34psi rear cold. Quote Link to comment Share on other sites More sharing options...
geordie82 Posted August 30, 2010 Share Posted August 30, 2010 This is where the tyresure monitors really come into there own, all four pressures and temps right in front of you every time you use the car. I have mine at 36psi front and 34psi rear cold. something worth looking into, 1st high performace car ive owned so had 32 all round, think i might need to adjust it a bit Quote Link to comment Share on other sites More sharing options...
Abz Posted August 31, 2010 Share Posted August 31, 2010 I keep forgetting! Thanks for the reminder Geo! Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted August 31, 2010 Share Posted August 31, 2010 Erm 13 psi and 17psi on the front whoops. Get em checked people. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 31, 2010 Share Posted August 31, 2010 I run 36 all round , for comfort, grip, tyre wear, fuel consumption I find it a good all rounder; Goodyear and Toyota also recommended 36psi all round after a quick call TRD Bilstein Shocks & TRD Lowering Springs 245 Front 19" Goodyear Eagle F1 GDS3; 275 Rear 19" Goodyear Eagle F1 GDS3 Depending on the Tyre Temps I find the PSI flucuates by 1 -2 PSI (I use a digital guage, in the same texaco garage every 2 weeks; Dont have any issues with people dropping the mechanical guage and affecting the calibration setting) ; Just goes to show the nightmare an F1 team or any racing team must have if I can see it on my road car Quote Link to comment Share on other sites More sharing options...
Wez Posted August 31, 2010 Share Posted August 31, 2010 They fluctuate a lot more than 1 or 2 psi Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 31, 2010 Share Posted August 31, 2010 They fluctuate a lot more than 1 or 2 psi Taught they might I just checked mine yesterday to find they were at 37psi on the rears after a motorway spin; never really seen them deviate for 1-2 psi but then again I check them after the same spin home from work on the motorway in the same garge , so very similar conditions each time Quote Link to comment Share on other sites More sharing options...
SPG Posted August 31, 2010 Share Posted August 31, 2010 Soo what happens if you have left your wheels and tyre's in Tue conservatory over yhe winter and the tyre's have been flat as a pancake, does this mean that they will be effected drastically? Quote Link to comment Share on other sites More sharing options...
