grinding noise from clutch
pauld36
hi does anyone have any info on the following please.
when engine started an in neutral no strange noises at all, but as soon as clutch depressed theres a sort of grinding sound.now ive had quite a few supras,and i remember the first one i had ,had the getrag box that also had a grind to it .
i spent a fortune having the thrust bearing changed and the gearbox stripped on that one an it didnt make the slightest difference[never got worse or better]
back to this one and although i dont mind spending money solving it [im thinking thrust bearing]but should point out its an os giken triple plate clutch an was wondering if its normal.
