Excel Question
far
Just write a little macro and attach a short cut key to it.
something like this will add a time and initial stamp to any cell when you press ctrl t.
Sub Macro2()
' Keyboard Shortcut: Ctrl+t
Dim timestamp As String
MyInitials = "JSJ"
timestamp = Now()
ActiveCell.FormulaR1C1 = ActiveCell.FormulaR1C1 & " " & timestamp & " - " & MyInitials
End Sub
thanks guys, erm I think I wasnt clear in my initial description - I dont want to update the entire date of the spreadsheet, I have a 'notes' column and when I go into the cells under this column I would like to add a date stamp as to when the note was added.
Jas, I think your solution would work - I will have a go at writing the macro, managed to find a tut on google
easiest way is to do the follwing.
tools>Macro>record new macro.
Name it appropriately, and stick in a letter of your choice in the shortcut key box.
click ok.
type some random stuff in the spreadsheet "iwg iugdeug" will do..
then go to
tools>Macro>stop recording.
then
tools>Macro>macros...
select the macro you just recorded and press edit.
code screen will open and you will see some code relating to your random typing (eg "iwg iugdeug" )
paste in the code in my first reply, save and close the VB screen.
when you ctrl + whatever key you specified now in your workbook it should date stamp it.
any probs give me a shout.
