Guest SupraTroopa Posted February 8, 2010 Share Posted February 8, 2010 Started getting this annoying problem on my supe, when pulling away or reversing (generally low speeds or when the clutch is held in for longer than a normal change) the clutch tends to stick to the floor and not return to the normal position. Tried bleeding the system incase it was some air in it but no joy. Any ideas? Quote Link to comment Share on other sites More sharing options...
Missile Posted February 8, 2010 Share Posted February 8, 2010 I’ve had this problem before. I had to replace the slave cylinder. But check to make sure your floor carpet is not in the way. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 8, 2010 Share Posted February 8, 2010 Possibly the bleed hole in the master cylinder is blocked, usual cause degraded brake fluid caused by seals wearing. New seal kits in master and slave and a proper clean and blow out, fresh fluid and bleed, job sorted. Unless the bores are worn or score, then new complete cylinders required. Quote Link to comment Share on other sites More sharing options...
Guest SupraTroopa Posted February 8, 2010 Share Posted February 8, 2010 Cheers for the responses guys, will have another look at the weekend. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted February 8, 2010 Share Posted February 8, 2010 Yep master cylinder, just had mine done. Quote Link to comment Share on other sites More sharing options...
