rear suspention
peter
hi, hope someone can help, we have just bought a tiptronic tt but are haveing a problem with the rear suspention, its ok on a flat road but when driven fast on an undulating road the suspention seems to bottom out also when going over a pot hole there is a loud thud from the rear as tho the suspention is hitting the bumpstop (if a sup has one!)
check and see if uv got loads of bags of cement in the boot....
loose suspension/chassis bolts, broken spring, knackered damper ??!?!?!
its not wheel arch scrub is it? does the car bounce around alot when driving? can u bounce the car while stood at any of the corners and does it return straight away or bounce for a couple of times??
Originally posted by peter
no bags of cement, we found there was no room we have to shovel it in loose, nothing under the car looks amiss all bolts tight,( which is wot I will be if I cannot find wots banging) would a set of blitz springs help?
Both the stock black ordinary Toyota shocks and springs and the factory Toyota Bilstein (yellow shocks) work fine with no thumps or bumps. Needs looking at by someone with Supra suspension experience (me...? ) Saw another post suggesting hatch rubbers, these go hard and rattle, rather than thump, but worth checking. DO NOT attempt changing them yourself until you know all the tricks, you can get in a real pickle if you knacker the screw heads, and that is really easy to do.
Hi again!
Funny I have the same prob in my VVTi - but only if I have a passenger.
I am getting the subframe bolts re-torqued when Leon does some work for me within the next few days (waiting for bits!)
See bottom half of this page
R
I had the same problem when I got my Supra. I was assured by the dealer I bought it from this was normal and that the suspension was stock. When I had had enough of the banging noise in the rear and bottoming out, I ordered a set of coilovers. When it came to taking the stock rears out the left shock was leaking and missing it's bump stop. Now that it's all changed it there are no strange noises as it should be.
