Cambelt change. Anything else while I'm at it?
Barnstormer
I did mine last weekend. Really easy job, longest part was getting the crank bolt off. I changed the water pump at the same time as it had never been changed & the cambelt has to be off to do it (i think). Managed to get a new one for £75 so it seemed like a no brainer. I also fitted a new crank pulley as mine was looking a bit wobbly. Maybe it was me being paranoid, but i had one fall apart on my old NA so i figured it was a good idea :)
The biggest thing you should consider is a billet timing belt tensioner bracket to replace your old OEM cast piece.
We have had countless numbers of people (my personal Supra included) snap theirs while driving or racing. It instantly wrecks your head and can tap your pistons and take them out to, especially if you do not immediately realize the problem and shut it down.
Happened to me 3 years ago. Cost me $2,900 with free labor and hook-up pricing from the manufacturers we buy from.
This can happen at ANY power level. It seems the OEM cast piece is wearing out on our Supras.
A $315 (USD) billet bracket can save you thousands. Ernie Skillen on here had it happen to his BPU Supra, as just one example off the top of my head.
Kind regards,
Dusty
I have heard of that. I replaced mine with a new OEM, a few months before you started producing those billet arms.
A new OEM is certainly better than a 15 year old cast piece, but I still don't trust the cast. We didn't realize the need for this piece until 2005 unfortunately.
IIRC, the 2JZ is a non-interference engine.
ok guys many thanks for the info. Will start on getting some more bits then! Have already got a new OEM tensioner and a Gates belt.
If you are DIY'ing then I'd 'consider' getting a new tensioner wheel bracket and crank pully, but in all honesty i'd leave the water pump, crank seal etc. They both aren't really problem areas and if they do fail they tend to give fair warning.........
From personal experience, i would definitely replace the front main oil seal. While the crank pulley is off its not a big job, but one its all back together it is :p
I know what you mean but when the labour 'cost' is just your own time and when a stock seal has no real known cyclical failure/replacement, time/rate (some just seem to go) and the fact that incorrect fitment of the new seal could mean you actually end up creating a leak when there was not one means for me i'd leave it and just get on with removing everything again in the unlikely event it did indeed start leaking soon after.......personal preference really it's a 'can do' not IMO a 'you'd be a fool not too' same as the water pump.
