Guest memonkeyboy Posted February 6, 2010 Share Posted February 6, 2010 hi i have a na 93 mk iv. a few months ago the engine overheated. a friend took out the thermostat and it ran fine for a few weeks then it overheated again and blew out the core plug in the water pump. i fitted a new pump and it ran fine for a few weeks now its overheating again this time its blown a hole in something over the inlet manifold lots of steam but hard to see where its from. the only thing i can think of, is the head gasket has blown, but it runs fine with no lumpy tick over and no white smoke and no white oil. i have looked at the other threads on here they all say white smoke? i dont think its an air lock i have disconected both heater pipes and run a hose pipe in all directions. any ideas please? Quote Link to comment Share on other sites More sharing options...
TLicense Posted February 6, 2010 Share Posted February 6, 2010 If you've got a stock rad it could be that. The plastic end-tanks can form micro cracks that mean it won't hold pressure so the car overheats. Either way get a pressure test done at a local garage and see where it's leaking from. They'll also be able to do a "sniff test" to see if their are any exhaust gases in the coolant which will tell you if it's a BHG. Quote Link to comment Share on other sites More sharing options...
Guest memonkeyboy Posted February 7, 2010 Share Posted February 7, 2010 hi thanks for your help i never gave that a thought, i was just about to replace the whole engine. what a muppet Quote Link to comment Share on other sites More sharing options...
