Just f**ked the engine
jevansio
  • Replies 301
Posted Images
Cheers guys,
I like Deans idea of putting a stock engine in, it's cheap & if I pull the swap off myself then everytime one goes bang it's only the cost of an engine (hopefully it'll be few & far between).
I also like the idea of a 3.4 though, it would be my ultimte goal, but maybe I should attempt a swap on a stock engine 1st incase I do anything wrong, no point me fecking up a £10k 3.4l lump.
Pop a new stock one in and build up the other.
Sounds like a valve to me, whatever, it sounds knackered :( You might just be lucky and damage is confined to the head. If it's dropped a valve you MUST account for cotters and stuff, things like that lurking about can do a LOT of damage.
Once the head is off if I get pics of the said items is it possible to tell if the damage is confined to the head, or should the block be sent to an expert to check?
What are cotters? :D
Sorry to hear this Jay.
I like your thinking on a stock engine. What about pulling your engine, fitting a stocker and then building up the fooked one on an engine stand?
Keep your head in the engine, no point in getting down about it. Whats done is done. At least you will have a good learning curve to concentrate on :)
Cheers bud, I'm starting to think that this car is more for me to fix rather than drive :D
So what causes a dropped valve?
Broken spring or cap come off i guess? is it a stock head? interested to see what you find, hope its a easy fix, if you need a head i have a good one of them spare also.
Head was supplied by Michel, ferrea valves, yeah I'm quite excited to see what's in there now myself
Bad luck :(
:D
Really appreciate all the help & offers (via pm also), what a club :thumbs:
Hopefully with the head off the extent of the damage will be visible I can decide the plan of action :)
I'm really starting to think the benefits of a fully built engine are a waste of time when revving to stock limits, when you offset the price of a stock engine vs a 3.0 built vs 3.4 built, the stock seems such a bargin.
