Guest argy911 Posted February 4, 2010 Share Posted February 4, 2010 I just got a second hand HKS GT2835 turbo kit and need some custom piping made for it. Does anyone know where I can get some ? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 4, 2010 Share Posted February 4, 2010 What custom piping do you need? 4"? 3"? You can get some stuff done at an exhaust fabricators. Most mandrels only go to 3" though. After that it is time to visit a fabricators with a lot of pipework Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted February 4, 2010 Share Posted February 4, 2010 What custom piping do you need? 4"? 3"? You can get some stuff done at an exhaust fabricators. Most mandrels only go to 3" though. After that it is time to visit a fabricators with a lot of pipework Not exaust piping .I need Oil feed . oil drain and water pipes. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 4, 2010 Share Posted February 4, 2010 Not exaust piping .I need Oil feed . oil drain and water pipes. Ahh, I thought you meant for the intercooler. Surely you can just use braided lines with earls fittings? Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted February 4, 2010 Share Posted February 4, 2010 Ahh, I thought you meant for the intercooler. Surely you can just use braided lines with earls fittings? I just googled earls fittings .I will call them tommorow . cheers mate. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 4, 2010 Share Posted February 4, 2010 You aren't doing this yourself are you? Who is doing the work for you? Bit worried about where this build is being done if they don't know about simple matters like this. Quote Link to comment Share on other sites More sharing options...
Wez Posted February 4, 2010 Share Posted February 4, 2010 Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted February 4, 2010 Share Posted February 4, 2010 The build is easy its the mapping thats the problem. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 4, 2010 Share Posted February 4, 2010 Yeah, clearly Quote Link to comment Share on other sites More sharing options...
Wez Posted February 4, 2010 Share Posted February 4, 2010 A HKS twin install is not a small task, even more so without everything needed. Have you done any builds like this before? What other supporting mods do you have in place before slapping these turbos on? http://www.speedflow.co.uk and http://www.thinkauto.com are two very good suppliers for lines of all types including oil and fuel etc, both will also assemble the lines for free if you provide all the info. Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted February 4, 2010 Share Posted February 4, 2010 A HKS twin install is not a small task, even more so without everything needed. Have you done any builds like this before? What other supporting mods do you have in place before slapping these turbos on? http://www.speedflow.co.uk and http://www.thinkauto.com are two very good suppliers for lines of all types including oil and fuel etc, both will also assemble the lines for free if you provide all the info. To me its a small task I've got all the mods for this set up Plus ryan G wont be maping this set up.. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 4, 2010 Share Posted February 4, 2010 To me its a small task I've got all the mods for this set up Plus ryan G wont be maping this set up.. Mate you didn't even know what to use as an oil return line so how can you say it is a small task to you? I wish you luck and all but come on, be honest with yourself here. You asked a question that anyone with half a clue of how to build a single setup would know how to answer. There is a big difference between bolting on a full single kit and having to customise parts for a twin setup. Quote Link to comment Share on other sites More sharing options...
TLicense Posted February 5, 2010 Share Posted February 5, 2010 To me its a small task I've got all the mods for this set up Good luck to you fella, sounds like you've got it all in hand then. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted February 5, 2010 Share Posted February 5, 2010 where did u get the kit from? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 5, 2010 Share Posted February 5, 2010 Plus ryan G wont be maping this set up.. Lol, who will be mapping it then? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 5, 2010 Share Posted February 5, 2010 Can I buy your twins when you blow up your engine? Quote Link to comment Share on other sites More sharing options...
supradibbs Posted February 5, 2010 Share Posted February 5, 2010 Contact any HKS dealer and they should be able to order them direct from HKS europe. Try Andy and sumo power Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted February 5, 2010 Share Posted February 5, 2010 Not exhaust piping .I need Oil feed . oil drain and water pipes. You'll need part numbers and from experience I suggest you buy the metal oil drain pipes and gaskets from HKS and fit better quality flexi's at the bottom and buy the HKS fittings for the block end. Feeds HKS complete also Water pipes, good quality custom fab Having had these on and off a few times I assure you that if you dont use all new gaskets you'll be a sorry puppy. How on earth did you get an incomplete kit? did it come from a reputable source? A copy of the HKS paperwork that comes with these will have part numbers on it, possible download form somewhere? Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 5, 2010 Share Posted February 5, 2010 I have copy of the HKS fitting instructions and parts listing if required, make sure you use good quality braided hose and heat proof covering on all the lines. Especially the wastgate lines as these are prone to melting, you need to be careful how you route them as well as its very tight on the Twin kit. Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted February 6, 2010 Share Posted February 6, 2010 where did u get the kit from? http://www.jps trading ltd Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 6, 2010 Share Posted February 6, 2010 http://www.jappartsspecialist.com/product_info.php?products_id=4776 ? Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 9, 2010 Share Posted February 9, 2010 http://www.jappartsspecialist.com/product_info.php?products_id=4776 ? If that is the kit there is not one bit of it that is original HKS 2835. This is a 2835 kit. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 9, 2010 Share Posted February 9, 2010 He didnt answer Lee Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 9, 2010 Share Posted February 9, 2010 Quote Link to comment Share on other sites More sharing options...
supradibbs Posted February 10, 2010 Share Posted February 10, 2010 Greddy wastegate???? plus the 2835 kit uses 2 wastegates that looks very odd too me. I dont trust that company either they had a T51 manifold for sale and were prepared to sell for 400 quid less than the ebay listing to deal off ebay and would not give me a invoice for money paid Doddgy as hell if you ask me Quote Link to comment Share on other sites More sharing options...
