One for the PC boffs [Vista]
jonathanc
Well I know there are a lot of PC savvy folks around here so I shall try to ask my question here.
I am trying to help my mate's dad to fix his PC. It's a Packard Bell (!!!) system running Vista32bit. His problem is that it takes a looooong while for it to boot up and sometimes also shut down.
I pinpointed the problem to be a service that takes very long to load up. Right now I am at the stage where I can boot up pretty quick and use Google but when I try to open Control Panel for example, it will take ageeees to load. Maybe around 6-8 minutes before everything is normal again.
I know reinstalling is probably the best solution but its a Packard Bell system that doesn't even come with a recovery disc. You have to make your own and since the system is mucked up at the moment there's no point of me making one now...
I am trying to disable services via msconfig at the moment but its taking a long while since it takes 10-ish minute just to boot up before I can restart... I have around 12 services active and also around 9 under startup but so far no luck yet of what's causing it.
I wonder if anyone encountered this type of problem before?
Also, if there a way to check the loading time for each services?
Many thanks.
My rig did this, turned out to be a hard drive was on the way out.
Hmmm, that doesn't sound very good....
I will just try to disable ALL services for now and see if that makes any difference. It's a rogue process somewhere that is basically hogging the system resource.
I am not sure why it lets certain programs to run (sometimes Kaspersky loads up fine but sometimes it loads up after the long wait for example). So I am guessing that if this rogue process/service loads before Kaspersky, then it will hog the system resource until its done.
Gaaaah, I hate Windows sometimes :p
