chazuk Posted February 4, 2010 Share Posted February 4, 2010 Does anyone know the bolt size and pitch for the 2 holes in the crank pulley used for the locking tool? I have a tool but cant remember which bolts I need ,I have tried a m8 bolt but the pitch is wrong. Quote Link to comment Share on other sites More sharing options...
Guest KSTUNING Posted February 4, 2010 Share Posted February 4, 2010 The 2 std ones from Toyota is either 6 or 8mm... Quote Link to comment Share on other sites More sharing options...
chrispot Posted February 5, 2010 Share Posted February 5, 2010 Does anyone know the bolt size and pitch for the 2 holes in the crank pulley used for the locking tool? I have a tool but cant remember which bolts I need ,I have tried a m8 bolt but the pitch is wrong. i don't no what size they are but are you using a standard m8 bolt that has a pitch of 1.25mm, there are a lot of bolts on the supra that use the metric fine thread, m8 bolt would use a 1mm pitch and m10 bolt would be 1.25mm, this could be the answer, hope you get it sorted, regards chris. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 5, 2010 Share Posted February 5, 2010 M8 x 1.25 mm pitch Use cap heads or something decent, not B&Q stuff.... Quote Link to comment Share on other sites More sharing options...
chazuk Posted February 8, 2010 Author Share Posted February 8, 2010 Thanks Chris and Chrispot , it was indeed a m8 with 1.25 pitch;) Quote Link to comment Share on other sites More sharing options...
